I would like some feedback on symptoms of bad caps. So far in my limited troubleshooting experience. In regards to Electrolytics any way that cooling a cap seems to bring out problem more so than heating. I notice that as a cap gets worse as in tv start up. It takes an increasing amount of attempts to get it to work. I conclude that each start attempt warms cap up a little bit. So cooling cap makes problem worse and heating cap tends to improve symptom. Anybody agree with this logic or am I just full of it?
Electrolitic troubleshooting
Re: Electrolitic troubleshooting
ESR goes down as temperature goes up, and opposite effect when cap is cool down.
Hair dryer is one of my tools.Last edited by budm; 11-09-2017, 10:36 PM.Never stop learning
And in my limited experience semi's seem to be the opposite as heat seems to break them down. So heating or cooling gives clues as to bad cap or bad semi. I have tv that works good for several hours. I heated control board and caused the problem. So likely not a bad cap but bad semi or connection?I assume no responsibility for any stupid suggestions I might post.
i try and localise the heat and find the general area then start warming caps one at a time with my iron .. please be aware to NOT do this with unit you are looking at plugged into the mains power as it will very likely cause a short circuit .. dont ask how i found that out ..
