Need bios LA-E811P
    Re: La-e811p rev 1.0 25Q64FWSIQ need BIOS please
    Originally posted by Smeek View Post
    still no display and no white light on charger connector (same like before).
    CPU get hot, i have 3.3v, 5v, 1.35v, 0.97v, 1.07v, and 3v on battery connector
    HP Notebook - 15-ra011nia
    Serial number : CND90554V8
    And some other versions you can try.
    Become a Badcaps supporter
    Thanks to all supporters.
      Re: Need bios LA-E811P
      La-e811p rev 2.0
      hp 15-bs009nk
      please i need it
        Originally posted by matoussi View Post
        La-e811p rev 2.0
        hp 15-bs009nk
        please i need it
        read this..
        why do you need ???more details.. post the original bios of the laptop..
          This version of Bios HP Notebook - 15-ra011nia.rar works for me very well
          Thank you very much sir.
            250 g6 dump anyone
              Hallo
              i need this bios!
              HP 15-ra048nh
              SN:CND9105YQL
              Prodid: 3QT62EA#AKC
              windows 10 installed the new Bios by itself! after that there was no display
              Very Thanks
                Originally posted by haziko View Post
                Hallo
                i need this bios!
                HP 15-ra048nh
                SN:CND9105YQL
                Prodid: 3QT62EA#AKC
                Very Thanks
                  From the official HP server! Is that good?
                    the original bios (the content of the bios chip) of the laptop... we also find the one on the website... read the bios chip from the laptop and post the content here..
                      I read this from the chip and saved it!
                      But the Laptop wouldn't start!
                      It installed Windows 10
                        use the 0832D bios from post #17...
                          Unfortunately it does not work!
                            You can convert the original BIOS so that it can be written with a chip writer, unfortunately WIN KEY+ B does not function!
                              if it doesn't work, either you wrote the bios with errors or the laptop has another problem..
                              what programmer do you have??
                                Ezp2023
                                  Power LED SLOW Blinking!
                                  After Windows Update, the system restarts! He updated the BIOS and then restarted, but there was no picture!
                                    Is it possible that the ENE KB9022 Rom is at fault?
                                      Ezp2023
                                      I don't know this programmer..I haven't worked with it..try to see a tutorial with it on the internet....if you write the bios correctly it will work..
                                        if the laptop doesn't turn on after you updated the bios, I don't think it's the KBC with problems... try again to write the bios chip.. then check the solder joints on the wiring of the bios chip.. don't use the clip but remove the bios chip before writing and reading according to the motherboard..
                                          the file 0832D bios from post #17
                                          work perfect.
                                          tested hp celeron
