Clevo W150HRMB-OD
    Clevo W150HRMB-OD
    Hello mates,,,
    I want a schematic for Clevo W150HRMB-OD.
    The laptop works fine but no screen leds on...
    I test 2 more screens with same results. No screen leds on.
    Any ideas?
    Thank you all.
    Re: Clevo W150HRMB-OD
    If external display OK but internal LVDS display not coming, there are multiple possibilities
    1] Screen failure - Less likely in your case as you have tried another screen already
    2] LVDS Cable failure
    3] One of the core LVDS supply is missing - check 19V LCD Backlight, 3V LCDVDD for Panel, Backlight on and PWM signals to control the backlight
    4] Discrete GPU Failure - Sometimes GPU failure may cause external display OK but LVDS display fail
    I believe the below Service manual is compatible with your model. It includes schematic diagram at Appendix B section
    https://cdn.badcaps-static.com/pdfs/...00aa56fffb.pdf
      extremely thanks for your reply...
      I have already found the schematic here :
      https://repo.palkeo.com/clevo-mirror/W1x0HRx/
      But it is a mess when I am trying to find lcd's cable pinouts in schematic
      It could be apriciated if someone knows the correct voltage per pin (the "wanted") for Led backlight trigger,,
      Thank you
        36,38,40 LEDP L_VIN = 19 volt
        33 BR IGH TN ESS_ R = between 1 - 3 volt
        28,30 PLVDD = 3.3 volt
        32 INV_ BL ON = 3.3 volt
          I will check 36,38,40 ... There is no 19v in any pin ...
          I really appreciate your help mate....
            Unfortunately no difference to screnn LED light when I placed 19v to 36,38,40...
            The other pins are voltage correct...
            Any ideas?
              ok... Finally I found a solution. I cut off 36-38-40 cables from base (red-orange-green), and I bridged them in 19v directly... Now laptop posts and screen LED back lights are fine... Thank you
