I have a Hannspree HF257 25" display that goes black after a couple seconds. After reading many posts, I replaced all of the caps on the board even though the cans did not looked popped on top. I also replaced the 12 v voltage regulator for good measure since the 12 v would shut down after a couple seconds. One of my friends said that was because it was probably in over current and it is one of those non-breakable regulators with a safety built in.
So, all the caps and regulator replaced, still have the same problem. I can see with a flashlight that the display is working, just no backlight. I suppose that leaves the inverters. I have been looking for the inverters on many sites and while you can buy just about every one on earth, you can't buy this one.
After searching, it looks like this may be the same inverter on the TDK XAD819AR inverter but I can't seem to find that one either.
I got this monitor for free and the problem doesn't seem like it should be so difficult to fix. I also reheated several solder joints that looked like they could have had ring fractures, I even pulled the inverters and reinstalled in the opposite position to see if that made any difference and still no help.
I would also be interested in figuring out what is pulling down the 12v.
One last bit of information, before i replaced the caps, i replaced the 12V regulator and the monitor worked for a few minutes before shutting down. Is it possible that the caps have damaged the regulator and now that I have new caps, the regulator needs to be replaced again? I know some circuits once they have tripped a few times the safety portion is damaged and will just keep shutting down.
Thanks for any help on this one. It seems to have a very common failure mode with this model but I have not seen any posts that have actually fixed the monitor except one where they jerry-rigged another model's power supply into the monitor. I think that is a bit extreme.
