Re: Korg Polysix synthesizer
Yeah you're better off staying with the same value or a little higher. It's not good practice to reduce capacitance unless you test and measure the system thoroughly and find it doesn't make a difference.
You don't want to go chasing another non-existent fault later on because you used capacitors that were too small. If the larger, paralleled ones fit, just use those.
