Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Thread Tools Display Modes
Old 06-07-2018, 11:05 AM   #181
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Cleaning Motherboards - ATTN SMOKERS!!
Had a for parts machine that I thought bringing back to life. Had a ASRock P4VM890, Delta DPS-300PB-2A and a VIA USB2 card.
I hope NOBODY has to live the hell I had to go through cleaning the PSU. Sweet Jesus Christ, I don't think I had a PSU smell that bad of nicotine and have so much dust.
I cleaned out the dust now. It still smells a bit (generally when warm) but it's mostly gone.
__________________
Main rig:
ASUS H61M-A
Core i3-3220 3.30GHz
MSI Twinfrozr GTX 750Ti 2GB GDDR5
6GB DDR3-1066
Samsung SH-224AB DVD-RW
Raidmax RX-500XT (recapped)
Seagate Barracuda ES.2 ST31000340NS 1TB
JNC RJA-52 case
Dan81 is online now   Reply With Quote
Old 06-07-2018, 04:07 PM   #182
christinejshaw
City & State: Toronto
My Country: Canada
I'm a: Knowledge Seeker
How do you clean a PSU?
christinejshaw is offline   Reply With Quote
Old 06-07-2018, 11:26 PM   #183
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I'm a: Professional Tech
Quote:
Same way you do a motherboard. Complete disassembly, hot water & simple green, and an air compressor to blow the water out of everything. I've cleaned a lot of them that way.
Here's a good example of hotwashing some PSU's: https://www.badcaps.net/forum/showpo...1&postcount=16
I do this all the time with stinky PSU's from houses of smokers. Like anything else electronic, just make sure its dried out good before firing it up. With an air compressor, you can wash, air compressor dry, reassemble, and power them up right away...I do it all the time.
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 06-07-2018, 11:47 PM   #184
christinejshaw
My Country: Canada
I'm a noob. I thought you could get zapped pretty good taking about a psu?
Old 06-07-2018, 11:55 PM   #185
Topcat
The Boss Stooge
Topcat's Avatar
If you're a noob, you might not want to try it.....but if the PSU is thoroughly & completely dry, its safe.
Old 06-08-2018, 12:15 AM   #186
christinejshaw
My Country: Canada
So if I open it up there is no risk of shock?
Old 06-08-2018, 12:21 AM   #187
Topcat
The Boss Stooge
Topcat's Avatar
If you remove power, it should discharge everything.
Old 06-08-2018, 12:23 AM   #188
christinejshaw
My Country: Canada
Awesome! I have a few lying around that I can run tests and clean them. You rock!
Old 06-08-2018, 09:14 AM   #189
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
To be on the safe side measure the big capacitors with a volt meter set to DC.
Sometimes they don't discharge, either because the discharge resistors are broken or none are installed...
__________________
Per Hansson is offline   Reply With Quote
Old 06-08-2018, 09:46 AM   #190
Topcat
The Boss Stooge
Topcat's Avatar
I did say *should* discharge... On old television sets I'd service back in the day, if servicing power supplies, I'd just take a screwdriver and short the leads on those caps, just to make sure they were drained. They'd occasionally create a nice spark!
Old 06-10-2018, 12:55 AM   #191
christinejshaw
My Country: Canada
It works perfect. I love this forum. Hat tip to you Top Cat!
Old 11-22-2019, 12:41 PM   #192
tvdad
City & State: Beverly Hills, California
My Country: USA
Lol thats what the inside of my laptop looked like last time i cleaned it
tvdad is offline   Reply With Quote
Old 12-17-2019, 05:54 AM   #193
Zane123
City & State: Birmingham
My Country: England
Hey I've just joined the forum after reading a few posts. I'm going to clean a motherboard with hot water and simple green. I don't have an air compressor. Can I dry it with a hairdryer? Or is it better if I leave it to air dry?
__________________
Zane123 is offline   Reply With Quote
Old 12-17-2019, 06:58 AM   #194
diif
City & State: Midlands
My Country: England
Quote:
__________________
I'd use a hair dryer over leaving to air dry.
diif is offline   Reply With Quote
Old 12-18-2019, 06:19 PM   #195
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Doesn't matter, both will work.
However, be advised that if you do use a hair dryer, the board could still have moisture/water trapped under the large BGA chips and some connectors, even if it looks dry on the outside. For this reason, I prefer to let my boards air dry. This takes more time, however. If you are looking for a speedier process, first let the board drain for about 30 minutes while placed vertically. After this, hit it with the hair drier until most of the moisture from the board is gone and the board feels warm. Finally, let the board sit for a day or two in a dry, airy place. I, for example, have have forced air heating (and cooling) at my place, so after doing the above, I then place the board sitting vertically above an air vent. Usually within a day, my stuff dries. But I typically let it sit for 2-3 at least.
Old 12-18-2019, 06:31 PM   #196
Topcat
The Boss Stooge
Topcat's Avatar
I dry them with the air compressor. Wash, dry, and powered back up...all within 10 minutes. Never had an issue!
Old 12-18-2019, 09:42 PM   #197
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
how about baking the board for an hour at 100C? this is used to remove moisture to prevent popcorning during reflows. can the same logic and technique be used to just make sure the bga chips are dry underneath before applying power?
ChaosLegionnaire is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
