eBay Chinese Electronic Clock Kit
    Re: eBay Chinese Electronic Clock Kit
    Originally posted by Rulycat View Post
    How do I know which way round the switch goes?
    Try removing it, its a push to reset switch, if its fitted wrong it could be holding the MCU in reset.
      i hoped to find a real schematic ..
      as an afterthought it should be easy enough to add a reverse polarity diode and fuse .. or even a bridge rectifier like some Philips radios had .
        <sarcasm>My WALL CLOCK runs at 12MHz! osofast...</sarcasm>
          Originally posted by Harvey View Post
          I assumed that too, but its to be connected through a diode to the vcc supply... unless the MCU has voltage sensing and goes into backup (no display) mode below a certain voltage.
          I also notice there is a resistor bypassing this diode (I can't make out the numbers on the circuit diagram) that CHARGES the 3V battery when connected to a supply! So DON'T use a standard 3V coin cell in there or you'll have another exploding component!.
          *EDIT * What goes on with R12 on your PCB? Trick of the light or has that only got one band?
          Yes it only has one band, but it came in the same strip as the others, so I think it is just a printing error.
          Tbh I hoped I could just solder it all and it'd work
            did you try it again yet ?
              Pete
              Still waiting on a replacement cap.
                LOL. Well, if you want to play that game, My wall clock runs at 1200Mhz.
                Follow the white rabbit.
                  damn it, mine only runs at about 80Mhz.
                    mine runs at 32.768 khz
                      Oh, and my watch runs at 360Hz. Can anyone guess the watch?
                        Pete
                        Try it with a 9V battery, it won't need that cap.
                          It's got a weird power supply. A 78L05 5V regulator then diode-drops D5 so the MCU runs off 4.3V and D6 for the LED display and colons. So on battery power, no LED's lit due to the blocking diode D6, and D5 also should have saved OP's parts from reverse-polarity. I would say the 78L05, C1, C2 are toast. It also micro-charges the lithium coin cell through R1 10k to +4.3V
                          You could try power it from 3 AA cells at 4.5V or remove the MCU and ensure the 5V rail works OK. It will work without C1 if the DC supply has a filter cap.
                          I can't believe how cheap these kits are. HS130110 SH-E 879 version.
                          I really like the other kits with DS3231 RTC, they don't drift.
                            78L05 Regulator Features:
                            5V Positive Voltage Regulator
                            Output Current upto 100mA
                            Maximum Input Voltage is 30V
                            Operating current(IQ) is 5mA
                            Internal Thermal Overload and Short circuit current limiting protection is available.
                            Available in TO-92,SO-8 and SOT-89 package
                              whatever do they mean by "available " ?
                                The 78L05 voltage regulator is offered in at least three different packages: TO-92 (through-hole), SOIC-8, BGA. Same IC inside.
                                It is the low current 100mA version of the LM7805 high current 1,000mA part in TO-220 and D2PAK packages.
                                I know from experience they die if you give them reverse voltage, at the input or output actually, like connecting a battery backwards to the output. Foof.
                                OP should verify it puts out 5V; not shorted and giving near raw value of the AC adapter or else the MCU will pop.
                                  So should I remove any components? Or just feed to the usual screw input with 3 x AAs?
                                    if you use 3 AA's you need to link the input and output of the 78l05
                                    you can do that by touching them with a screwdriver - for a quick test.
                                      Sorry gents will do this just waiting on the 3xaa battery box to arrive.
                                        It's working! Didn't have to short the 7805.
                                        You'll notice I replaced the cap there as well.
                                        Does this mean the transistor isn't cooked?
                                        Haven't installed the switch yet.
                                          regulator might be shorted
