cant quite read it as hole blown through ...
is this a NCP1014AP065G ?
Re: is this a NCP1014AP065G ?
Getting a bit o/t, but if your TV PSU has Active PFC (APFC), you might want to make sure that circuit is running as it should be and not overshooting. Main capacitor going open-circuit can be attribute to either bad part (crap cap brand) or APFC overshooting and killing the cap over time. Usually it's #1, but I've seen the latter wreck even good quality brands too. Something to keep in mind after replacing the main capacitor and that NCP1014 chip.
there are 2 bulged caps on the board i am replacing as well .
bit of history .tv always worked well but would sometimes forget what source was selected when coming out of standby .. i had been away a week and on my return i plugged the tv back in and no standby . grabbed the hair dryer and warmed it up .stand by light come on and switched on fine .left it on and ok for first night . next night it was off when i woke up . no standby light . so far found this ic blown up . 2 bulged 4700uf 6.3v caps and main 150uf 450v cap open . plus a blackened open fuse .
open cap is a capxonLast edited by petehall347; 09-28-2018, 04:27 AM.
sorry its back together .. tv is an odd one locally built . evesham computers was one of their company names . think they are out of business now . hold on might have got a pic will check the phone .
edit ..sorry only a pic of chip . i did have a tab open with same one but long closed it . will see if in historyLast edited by petehall347; 10-07-2018, 05:35 PM.
