Hi, I have a HP Pavilion x360 - 15-dq0007nc (just about 26 months old) with burned mosfet. Sadly I didn't found any boardview or schematic for this model, so I need your help with this.
The mosfet right next to it is probably SM3319NSQA N-channel.
The burned one is connected to a Sic634 pin 8-11 "Power stage input voltage. Drain of high-side MOSFET" So it should be a P-channel? Can you help me with finding the right replacement?
Also I measured about 15 ohms to the ground on the coil. But I didn't remove the burned stuff yet - it will wait until monday when I can use the microscope for this.
Thanks for your help
