ideapad 3 15iil05 gs454/gs 554/gv 450/gv 550 nm-d031 disable onboard ram
    i have ideapad 3 15iil05 board gs454/gs 554/gv 450/gv 550 nm-d031,
    someone can help me to disable onboard ram?
    is possible just swap resistor?
    here board pic
    thank in advance for any help
    Re: ideapad 3 15iil05 gs454/gs 554/gv 450/gv 550 nm-d031 disable onboard ram
    i have the solution for this
      Are you going to share it then ?
        can you please share the solution for this
          ok
            ok
            can you share please
              The OP of this comment has pm'd and will share the details soon.
                ok
                can you please share too? now the laptop click power on no display out...considering is stuck on the ram.
                  ok
                  Hello!! Will you have the solution please to disable the memory? Thank you
                    I would be grateful for the solution. Same problem. Stuck on POST 15
                    Could you help?
                      here board pic
                      please share bios backup
                        use the forum search , already posted in a bios requests thread https://www.badcaps.net/forum/showth...hlight=nm-d031
                          Hello, could you please share the method to disable the onboard ram. From already thank you very much
                            He'is not going to share it here and that's pretty clear. Not to annoy anyone but there are members here who use this forum to further there business and are certainly not interested to help others on honorary basis. The onboard ram on this mb can be disabled through bios editing but i dont know how.
                              how to disable ram??
                                Quizás a alguien le sirva, puse el ID de la placa de 6-9 a 0100 y la memoria se apagó, no hace falta desoldarla, subo una foto, en rojo las posiciones donde hay que mover las resistencias a lugares verdes. A MI ME SIRVIO
                                Maybe it will help someone, I put the ID of the board from 6-9 to 0100 and the memory turned off, it is not necessary to desolder it, I upload a photo, in red the positions where you have to move the resistors to green places. IT SERVED ME
                                  id 6-9 0100 or 1000, ? in the picture i see 1000 or i'm wrong
                                    Can anybody help me to disable RAM?There is no resistors like at the picture above !!!although my motherboard looks the same.
                                      It worked for me! Thank you so much.
                                        You got exactly the same motherboard version as mine, just move the resistor RC825 to the RC827 place, and remove RC840.
