I'm not having much luck with AM2 boards - this GA-M51GM-S2G looks perfect, but neither onboard graphics nor PCIE x16 slot work
The board POSTs with a single beep, but I get a display only if I use a PCI graphics card - other than that, nothing
A clean install of XP with PCI graphics reckons another, GeForce 6100, graphics device is there - but nothing shows up on a 2nd monitor connected to onboard graphics
If I remove PCI card, and set BIOS to "Set Init Display First to onboard VGA" and "Always output from the onboard GPU", it boots with a single beep then loads XP with no display, presumably without a hitch because it does shut down with Alt-F4 & Alt-S
I've tried both powered and non-powered PCIE graphics cards, also updated latest non-Beta BIOS F15 - both to no avail
Any suggestions ? - or is this another nVidia dud ?
