Epox MGF6100-M goes to sleep, does not wake up
    I installed this board (NF6100 + NF410 DDR2) with Athlon FX-62 CPU into an Acer AM1640 case.
    Everything works OK, but whenthe machine goes to sleep I have to power down and restart.
    I used the existing FSP 250-watt power supply, which on the original MSI board supported a 1.86Ghz Core 2 Duo. The date of manufacure was mid-2008.
    Can I change the power options in the BIOS to fix this, or is this more likely a hardware problem? The default poer setting was S1.
    For the moment, I have changed the timeout setting to 1 hour in Linux Mint 13 Maya.
