Denon 4308CI NO AUDIO
    I picked up a Denon 4308CI cheap and the unit powers on fine but I have no audio output. I tore the unit down and found on the audio unit board a bad cap and a blown transistor. C507 100uF 50V and TR501 KTA1268. The KTA1268 is not available so I need to find something equivalent.
    https://cdn.badcaps-static.com/pdfs/...fffd426395.pdf
    This one is close but not exact.
    Any recomendations?
    Re: Denon 4308CI NO AUDIO
    992 is only rated at 50mA Ic, 1268 is rated at 100mA.
      I cannot find an exact match at digikey or mouser.
      I can go 1/2 the rated voltage
      or
      Higher voltage and less gain
      Or I can try my chances on eBay transistors which are probably fake.
        You could also contact Digikey, and they may suggest something.
          Never thought to do that. Thank You
            They recommended these:
            https://www.digikey.com/product-deta...X795A-ND/92573
            Parts ordered let's see what happens. I am replacing all of the caps in that section as one of them ruptured, which most likely killed the transistor with noise the other parts seem to test ok.
              I recapped that section of the board and replaced the PNP with
              The transistor blew again when powered on so another problem exists.
                Any ideas on this one because these look like the muting circuits they shouldn't have excessive current flowing through them.
                  Hard to tell without the service manual. The partial schematic you posted does'nt even show C507.
                    I found a schematic, I take it the transistor shorted? if you remove it, what voltage do you get on TR501 collector (C503) it should be around -7 volts. also check the base voltage (d511 anode)
                    What was wrong with C507? You should check the voltage on each side of C507, you should have -12v on the negative and possibly +5v on the positive lead.
                    (Page169)
                      C507 was blistered and leaking, could be an un-related problem. I checked the voltage rails and everything seems to be good there.
                      I will test the things you listed tomorrow.
                        More problems found:
                        B - 34V
                        C - 10V
                        E - 61V
                        I unplugged CW155 & CW068
                        B - 100mV
                        C - -3.88V
                        E - 475mV
                        More checking shows both transistors (TR630 TR631) on the 5V supply are shorted and I have a blown audio output. IC301 is also fried. My guess is the blown output is the cause. I am not sure that I can find a replacement for the outputs. IC301 might also be impossible to source. I am not sure if I trust eBay parts but that may be my only option. I have the service manual but it is too large to post.
                          Must have been a big boom.
                            Trace Repaired:
                              Have you checked the main amplifier transistors? Usually when they short they take some smaller transistors also.
                                http://pacificsemi.com/search.php
                                SAP15N
                                  Mains were blown. I also found a bad diode.
                                  https://www.digikey.com/product-deta...03P-ND/3661836
