Hi
I'm trying to restore a Kenwood Chef A901e, the one with the PCB motor controller but I'm struggling a bit with the correct wiring layout. I've replaced all the caps and triac plus the 56 Ohm resistor.
If we look at the pcb from the top with the heatsink/triac to the right:
Terminal 1: below 150nf cap
Terminal 2: above and to left of 150nf cap
Terminal 3: above and to right of 100nf cap
Terminal 4: heatsink
| have wired it up as follows:
Terminal 1: blue from connector block and yellow from motor
Terminal 2: brown from reset button
Terminal 3: pink from motor
Terminal 4: blue from motor
I can't work out where the red from the motor should be connected, also some photos of pcb boards show a jumper wire from terminal 2 to 3 but some do not.
Hope you can help and thank you very much for taking the time to look.
