Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 12-02-2019, 11:36 PM   #41
redwire
City & State: Alberta
My Country: Canada
Default Re: Wine Enthusiast wine cooler, no power. Model # 272 03 29
It's so you can take out the board and put it back in, without screwing up the connectors. Did you notice four are all the same 2-pin connector and can get mixed up!
I use a felt pen and put a stripe or dot (or two), or you can use masking tape etc to label the wires - CN1 (connector 1) etc. FAN, TEMP SENSOR, LEDs, PELTIER module etc.
redwire is offline   Reply With Quote
Old 12-03-2019, 06:16 PM   #42
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Quote:
Originally Posted by ajsterr4 View Post
I'd like to do it on a table, why would labeling wires help me?
The reason for doing this is IF you have a bunch of wires that are the same exact color or IF you have connectors have the same profile
How will you know which wire OR which connector went where
If you hook wires or connectors in the wrong place at a minimum nothing will happen or the hole board could go up in flames or blow fuse or circuit breaker
This is the reason for labeling wires or connectors and take pictures
I hope this helps you understand why I made this comment before
I do this most of the time when I work on board unless the board is marked with the wire number or jumper number and even then I will take pictures of the board any way
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
