Re: Aspire a315 DA0ZAVMB8E0 REV E no power , no charge no led . DEAD
I worry you have bad case
in example you've bad case:
PU8001 AOZ5049 was bad, there is High Side mosfet inside the package of small QFN. When HS fet shorted ( VIN#1 and VIN#2 -pin 6 and 22 look will being a single wire that goes to pin VSW#1 and VSW#2), If your CPU is good and have resistance approx 7 ohm on VCCCore. Resistance on +VIN (19V for system) will same with resitance on VCCCore. If you inject 5V on +VIN line then you have 4V over. (also PU8003-PU8005)
Or If you have HS fet PQ22 was shorted. then you have 2V over. Maybe via 3v rtc although the currents will reduced via R147.
Or if you have bad PU16...
There isn't +VIN line on good mobo will direct to chipset or CPU, unless you have something went wrong on circuits. Usually most likely High side mosfet or bad IC controller (which have Highside mosfet inside QFN package)
Initially was no short but totally dead , replaced PD1 but now i got short , when i plug a charger it , go in protection.
Measuring in diode mode on pin 3 i got 0 short to ground . What can be checked ??? can i inject voltage with bench psu to detect heat?
Good day.
Can you suggest or give a link to this scheme( DA0ZAVMB8E0 REV E)?
thanks in advance
