HP Probook 640 G2 bios dump
    Re: Slow Start HP 640 G2 Probook - Bios
    Originally posted by GValdameri View Post
    Attached are the two files for comparison.
    Try this bios ,it has NO dmi so you`ll need to use nbdmifit/HP BCU .
      try this and report
        HP ProBook 640 G2 MPM
        HP ProBook 640 G2 MPM.How to solve this problem
          Re: HP ProBook 640 G2 MPM
          https://www.youtube.com/watch?v=9T57ktw8n3Y
            I've tried it but it won't
              Post here bios file.Use bios programmer.
                Here is the bios file
                  Before i told you for bios you use bios programmer.Need bios 16mb if you want solve this error.File is 16mb but not have data.
                    Here I read it again
                      same thing ..remove the bios chip from the motherboard before reading or writing ..
                        This was read with RT809H
                            if the bios is ok, try entering the DMI information
                              All I get when I boot from usb flash is this.
                                what motherboard code do you have ???
                                  Try this.
                                    try this
                                    HTML Code:
                                    [ATTACH]231495[/ATTACH]
                                      HP 640 G2 Bios Request
                                      Hi Guys,
                                      I have a machine a customer brought in, HP 640 G2 with a corrupt bios.
                                      Mobo model number is circus-6050a2723701-mb-a02
                                      The machine was working fine and they did a bios update, screen went black and nothing else after that.
                                      caps lock blinks 5 times and fan runs at high speed.
                                      They did make a backup of the bios before starting the upgrade, but no auto recovery method seems to work.
                                      In the folder of the recovery bios, there is 3 files.
                                      The 0151 zip file contains 2 bios files N76 and N87, with date modified 2020/10/23
                                      The N76_0147 zip file contains N76 bios file, modified date on this one is the date of the failed bios update.
                                      The files are 9 216kb, the bios should be 16mb.
                                      I have already tried a few bios files without any luck.
                                      Can anyone please rebuild the bios ?
                                        Re: HP 640 G2 Bios Request
                                        This bios worked https://www.badcaps.net/forum/showpo...7&postcount=12
                                          hey hello boys i have a problem with 640 g2 , i lflash the image bios from forum its turn on my laptop but i dosent charge the battery nd it stay in commitet state behind i put serial etc.
                                          first is my original bios, 2 nd its the image i find in forum
                                          Last edited by klean; 12-15-2021, 04:47 AM. Reason: i forget to upload my atachment
