Old 08-09-2018, 03:17 AM   #1
Y. Signal
Y. Signal's Avatar
City & State: South Spain
My Country: Spain
Line Voltage: 230VAC 50Hz
Question Thomson 32HB3103 sound problem
Hello. This TV from grandma has a problem and I'd be very happy to repair it.
When I turn the TV on, after 20 minutes or so the sound stops. When I turn it off and wait some minutes and then I turn it on the sound works again but it's periodically interrupted by silence.
I have taken a photo and all the capacitors look fine, anyway since this does not mean they're working well, should I do a complete recap? any idea or something to check or try before ordering new caps?
The speakers are connected with the black&white and black&red connectors at the top right of the photo.
Y. Signal is offline   Reply With Quote
Old 08-09-2018, 03:33 AM   #2
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Default Re: Thomson 32HB3103 sound problem
When the sound drops out if you spray the IC below the connectors (24/28 pin IC) with freezer spray does the sound come back up.
dick_barton is offline   Reply With Quote
Old 08-09-2018, 05:10 AM   #3
Y. Signal
Y. Signal's Avatar
My Country: Spain
I'm going to look for that spray and try. Will report back.
You mean the 28 pins SMD IC that appears at the right black capacitor and below 4 inductors marked with "220", isn't it? It's marked as TPA3110D2
Old 08-09-2018, 07:22 AM   #4
Y. Signal
Y. Signal's Avatar
My Country: Spain
I've let the TV turned on for a while with the case opened and the sound is working nice, so it must be a heat issue.
I've carefully touched the TPA3110D2 and it's not very hot. However, the aluminum heatsink located under "CQC" letters is burning hot... I plan to remove it, clean the surface with isopropanol and use a new adhesive thermal tape and a bigger heatsink if I find one that fits.
I have tried unsuccessfully to gently remove the heatsink but it seems attached to the IC with some kind of white glue instead of thermal adhesive tape... it looks to be the same used near the large capacitor, is this practice common?. Any idea?
Old 08-09-2018, 07:44 AM   #5
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
have you got a fan you can blow on too the back of the tv, you will know if its a heat related issue then and those ics do run hot some people mount a computer fan on the back casing over that area too keep it cool.
vinceroger69 is online now   Reply With Quote
Old 08-09-2018, 07:46 AM   #6
Y. Signal
Y. Signal's Avatar
My Country: Spain
Thanks. I'll let the TV run for more time with a fan to be sure it's a heat problem.
Old 10-08-2019, 01:28 PM   #7
gtferrari
City & State: Athens
My Country: Greece
Hi! Did you solved the problem? I have the same problem. In my TV, when I use external speakers or headphone using the headphones jack (the green one) the work perfect. The problem is when the sound goes to the internal speakers.
gtferrari is offline   Reply With Quote
Old 10-08-2019, 01:55 PM   #8
petehall347
City & State: worcester
My Country: United Kingdom
check ohms on internal speakers
Old 10-08-2019, 01:56 PM   #9
petehall347
just thought headphones may be a different amplifier . check speakers anyway
