Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 02-19-2018, 05:56 AM   #1
jarvis7
City & State: sasd
My Country: asasf
Default Android Oscilloscopes , Cheap and good enough to test desktop PSUs reliably ?
Hello ,
I found some of these videos on youtube , it seems like a super cheap way of making oscilloscope , with some old spare android device
https://www.youtube.com/watch?v=xFA9CdusDWg
https://retronics.wordpress.com/2012...-oscilloscope/
i know they won't be super accurate but are these types atleast good enough to check Spikes and Ripple output of desktop PSUs to determine whether PSU is outputting Safe and stable voltage quality reliably ?
any experiences, thoughts , comments ?
Thank you ..
jarvis7 is offline   Reply With Quote
Old 02-19-2018, 08:15 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Android Oscilloscopes , Cheap and good enough to test PSU ?
it's not about accuracy for most tests, it's about being fast enough.
i would say you need 200-500KHz - preferably 500+ to check for ripple on a psu, because most run at 60-80KHz and you need 5x that to get a good capture.
so it's going to depend on the maximum bandwidth of the phone you use.
Old 02-19-2018, 10:09 AM   #3
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Agreed. In general these "sound card oscilloscopes" are only good for ... sound.
Therefore, good only for debugging audio problems, and possibly linear PSUs.
Ugh, I can't believe that guy in the video that got rid of their bench scope "for bench space," must not be serious of an experimenter or assumes there will be an IC that will handle all the high frequency stuff...
eccerr0r is offline   Reply With Quote
Old 02-19-2018, 04:46 PM   #4
clearchris
clearchris's Avatar
City & State: San Antonio
My Country: United States
Line Voltage: 120v 60hz / 240v 60hz
I'm a: Hardcore Geek
When you need to get rid of your scope for "bench space" you need a bigger bench.
clearchris is offline   Reply With Quote
Old 02-19-2018, 05:45 PM   #5
dmill89
City & State: Harrisburg, PA
^This,
I see the OP doesn't list a location, if you're in the US <$50 analogue scopes are pretty easy to come by (especially brands other than Tektronix and HP, you'll often need to add you're own probe, but the <$10 eBay/Amazon probes work fine), most you'll find in this price range are 10-30mhz, but that is more than enough for PSUs.
There are also the $20-30 kits on eBay/Amazon/etc., though they're only rated for 200Khz (and often don't perfrom well above 100Khz) so still definitely on the low side for PSU ripple, but better than a sound-card based scope (most phone sound cards aren't going to handle anything above 20 KHz).
dmill89 is offline   Reply With Quote
Old 02-20-2018, 01:19 PM   #6
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
I was thinking about selling my old 20MHz scope, because I'm out of bench space
( but I can say that because I have two other 300MHz scopes...
Alas, this 20MHz scope can run on 12VDC whereas the two Teks cannot without an external inverter...)
Old 02-20-2018, 03:14 PM   #7
jarvis7
City & State: sasd
My Country: asasf
So , not useful at all then for PSU..
Thank you very much Stj , eccerr0r , clearchris , dmill89 sir
