Old 05-21-2006, 07:00 PM   #1
itry
Unhappy eMachine No Signal
Hi, all. I'm getting a bit frustrated with my pc (eMachine, big surprise). It's a T1840 and I started getting a "No Signal" awhile ago but was able to start in safe mode. Now I can't even do that. The cable is okay so I tried to change the video card but now it won't even let me get into safe mode. When I turn it on I get a series of beeps - 1, 3, 3, 1. Everything is plugged in as before. I removed the new video card. I have no idea what to do at this point. I've been reading other threads on this kind of problem but have only gotten more confused. Should I just give up and get a new machine? If you reply, please be easy on the tech-speech - I'm not exactly well versed in it. Thanks!!
itry is offline   Reply With Quote
Old 05-21-2006, 08:42 PM   #2
Galvanized
Galvanized's Avatar
City & State: SoCal,USA
Default Re: eMachine No Signal
Look up the motherboard brand/type, look up the BIOS used, there can only be about three. Award and AMI are two. Look up the beep codes and it will probably indicate a video or RAM problem. Reseat the RAM and try again. Try with only one stick, if you have two in use.
Close to 30% of comp problems are PSU related. If you have a spare PSU, hook it up and see if it boots...After you clear the CMOS(Google it or use the manual).
Here's a basic but VG flow chart: http://www.fonerbooks.com/pcrepair.htm
Since this is badcaps, has the motherboard been closly examined for them? The PSU would have to be opened up to have a look-see.
Best of luck itry with your problem & first post.
Galvanized is offline   Reply With Quote
Old 05-22-2006, 11:19 AM   #3
MD Willington
MD Willington's Avatar
City & State: WA, USA.
Trigem Imperial mainboard:
http://www.emachineupgraders.info/di...imperial.shtml
System BIOS Core Brand: Phoenix
Ya'll think us folk from the country's real funny-like, dontcha?
The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
MD Willington is offline   Reply With Quote
Old 05-22-2006, 07:08 PM   #4
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
the bestec psu often kills these boards.i have seen +5stby at 11v!
dump it now.
if you get a replacement board dont try it on the old psu!
kc8adu is offline   Reply With Quote
Old 05-28-2006, 12:04 PM   #5
Galvanized
Galvanized's Avatar
itry, mark this site: http://www.computerhope.com/beep.htm
Note: Do not discount what kc8adu has to say above this post, the man has cred.
Old 05-28-2006, 12:42 PM   #6
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
he has done more rework than we have had hot dinners.
willawake is offline   Reply With Quote
Old 05-28-2006, 05:01 PM   #7
Spacedye69
Spacedye69's Avatar
City & State: Greenville, OH
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Got the same code on a board I just recapped. Someone had "de-capped" the board by just pulling the caps off the board , so I didn't see the bulging ones. I replaced the missing caps, and 1-3-3-1 was all I would get. Replaced the rest of the caps at vrm, which looked ok, and everything is fine! I had never seen Sanyo caps before, but apparently they can be bad without bulging. Pheonix/Award bios btw.
Spacedye69 is offline   Reply With Quote
