Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Old 08-05-2010, 11:30 AM   #1
JuniperSprouts
Solder Soldier
JuniperSprouts's Avatar
City & State: Deep South
Question computer on 2 networks
Here is a "rough" estimate of my planned network:
My question:
I am password-protecting my workshop router. If I receive this signal at my upstairs dish/router, how/where do I put in the password? The upstairs thin client has an ethernet cable going to the upstairs router. That is to say, how will my upstairs thin client be allowed to log on to the Workshop network?
(The upstairs thin client will be controlled (VNC or RDP) by the upstairs computer.)
Thanks ahead of time,
Jaime
JuniperSprouts is offline   Reply With Quote
Old 08-05-2010, 02:18 PM   #2
retiredcaps
City & State: Canada
Default Re: computer on 2 networks
What type of routers do you have are planning to use?
Old 08-05-2010, 02:32 PM   #3
JuniperSprouts
Solder Soldier
Thumbs up Re: computer on 2 networks
I have a couple Linksys WRT54G routers. I am open to other options/suggestions.
I do not know in which "mode" the upstairs router should be. I have set up dozens of simple home networks. This is new to me.
Thanks for any help.
Old 08-05-2010, 02:45 PM   #4
retiredcaps
The WRT54G are perfect for this application. Although, I'm a bit hesitant helping someone with a "Juniper" screen name with a Cisco product!
You have a couple of alternatives.
1) The Wireless Repeater mode will turn the access point into a wireless repeater to extend the range of your signal.
http://linksys.custhelp.com/cgi-bin/...p?p_faqid=4200
2) The Access Point Client mode allows the WAP54G to act as a wireless client.
http://linksys.custhelp.com/cgi-bin/...i=&p_topview=1
I assume your thin client has 2 ethernet ports?
Old 08-05-2010, 06:15 PM   #5
JuniperSprouts
Solder Soldier
Haha! I still have a hard time thinking of Linksys as a Cisco entity.
Thank you for the short & sweet answers. I asked at another forum. Some jerk just kept hassling me about how thin client computing was not cost-effective & was "out of date." I just picked up a $30 unit for fun, learning, and big savings on the number of watts the thing will pull.
WAP Client mode - perfect. You even gave links with instructions - very nice.
The client does have 2 NICs.
Thanks for taking the time to help me out. It has given me information & confidence.
-Jaime
Old 08-05-2010, 10:03 PM   #6
retiredcaps
You are welcome. Always glad to help out where I actually have some expertise.
Old 08-05-2010, 11:05 PM   #7
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
looks more complex than mine... at least the only wifi on it is form a router to a laptop:
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 08-06-2010, 04:46 AM   #8
seanc
City & State: Cambridge, UK
Ratdude, you'll have a slightly nicer networking experience if you replace the hub with a switch, when life permits.
seanc is offline   Reply With Quote
Old 08-06-2010, 09:54 AM   #9
ratdude747
Black Sheep
ratdude747's Avatar
it IS a switch...
it is this model:
http://www.geeks.com/details.asp?Inv...008C&cpc=RECOM
i found it at a surplus place for $5, and needed one bad, so i took it. it does well...
i did not know there was a difference between hub and switch.
fixed:
Old 08-06-2010, 10:08 AM   #10
smason
smason's Avatar
City & State: Alberta
My Country: Canada
Line Voltage: 120VAC 61Hz
I'm a: Hobbyist Tech
LOL! Like my dad used to say, "You can't polish a turd"
Slapping a Cisco sticker on Linksys crap, gives you the same old crap with a shiny new sticker.
smason is offline   Reply With Quote
Old 08-06-2010, 11:10 AM   #11
retiredcaps
Good price for a 10/100 switch.
Hubs work at layer 1 (aka simple repeater) Switches work at layer 2 or layer 3 depending on the implementation. Yours is a layer 2 switch.
Hubs were probably "before your time". You won't see hubs much nowadays. Just like thicknet or thinnet (for the guys that were involved with ethernet at the very beginning).
Old 08-06-2010, 12:46 PM   #12
ratdude747
Black Sheep
ratdude747's Avatar
i see
i have an old hub with both 10baseT and 10base2... lol. not in service though...
Old 08-06-2010, 02:38 PM   #13
retiredcaps
i see
Just to expand a bit more. It is more complex than this, but ...
layer2 means the switch looks at the ethernet destination mac address and forwards it to the correct outbound port.
layer3 means the switch looks at the higher layer protocol destination address (for example, tcp/ip) and forwards it to the correct outbound port.
My first network install was an arcnet over coax cable with Novell 2.11 on 1.2Mb diskettes running on a Compaq Deskpro 286 with 4MB (I think) of memory.
Old 08-06-2010, 03:30 PM   #14
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Yea, and a hub does not look at all on the packets
It simply receives a packet on one port then sends it out an all ports (since it does not know who the recipient of the packet is)
So a hub is way less efficient, it also makes the computers NIC's (and processors if it has cheap NIC's) work much harder to shift through all the packets not destined for it
You can imagine how easily saturated a 10mbps or 100mbps HUB network is, just one computer transmitting at full speed will use up all bandwidth
With a switch however (if it's a good one, with a good backbone) you can transmit at 100mbps between each of the computers that are connected to the switch at once, in effect using several gigabits of traffic on a 48port 100mbps switch...
Old 08-09-2010, 03:22 PM   #15
kaniki
City & State: City of Idiots, Pennsylvania
you forgot to add one thing.. hubs usually just forward the info on and work more like a standard splitter, meaning you loose signal strength as it goes through the hub. A switch will not only direct it to the correct port, but also works like a amplifier and strengthens the signal for better transmission lengths and accuracy.
kaniki is offline   Reply With Quote
Old 08-10-2010, 10:32 AM   #16
Per Hansson
City & State: ----
My Country: Sweden
Wow, thank you soooo much for this information
An old A+ book (and teacher) I had said that you can only daisy chain up to 3 switches
So what they meant was infact 3 hubs!
I have been thinking about this ever since that day, and never bothered to ask anyone else
As what I was told and read I accepted, but did not believe actually, since I had personally seen networks with over 500 computers, but only switches, not a single router, you can imagine how many switch "hops" the furthest away computers had, which where actually in different buildings etc, some miles apart connected with fibre!
Old 08-10-2010, 10:42 AM   #17
retiredcaps
That design above is a network meltdown in the making. A single L2 network across multiple buildings and connected miles apart via fibre has so many design problems, I can't even begin to list.
Old 08-10-2010, 10:48 AM   #18
Per Hansson
City & State: ----
My Country: Sweden
retiredcaps; it sure is, and I told them many times, they knew this too...
But you know, since it was the government does it surprise?
Atleast the hospital had it's own router so was separate from the rest of the crap
Old 08-10-2010, 10:52 PM   #19
Uranium-235
Muffins
Uranium-235's Avatar
City & State: tehas
My Country: US
you can network as many hubs or switches as you want, but with hubs, you have one giant collision domain, and that is bad
you can always use a linux router distro with wifi cards, and bridge the two
Uranium-235 is offline   Reply With Quote
