Hey guys, I have an ABIT KT7 RAID motherboard that will only POST every other time I try it.
When first powering it up, all the fans and drives spin up but I get no display and no beep. If I then turn the switch off on the power supply while it is running and wait for everything to stop and try again, it boots up just fine and works great until I shut it off.
It doesn't matter if it has sat for a while or if I was just using it, it always takes exactly 2 tries to get it to POST.
Rebooting from windows also doesn't work as it just hangs in the exact same way and I have to turn the power supply switch off and on again for it to boot.
I know capacitors going bad can cause all sorts of strange issues but since this problem is so specific and repeatable does it really sound like bad caps? None of the caps are swollen or leaking.
