Charger circuit questions
    I would like to modify this simple charger (for lithium ion cells) so that it will stop charging at a lower voltage.
    The IC used is HX-3H1227. I could not find the datasheet from the internet. I have send e-mail to the manufacturer or factory asking for the datasheet and got a reply saying that they also could not find it.
    I would like to know if somebody can help me on getting the datasheet and/or how to lower the stop charging voltage.
    Re: Charger circuit questions
    A couple of things what is the input voltage
    The second thing what is the two diodes that are Zener diodes what are the are the part numbers or the voltage on the output of diodes
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Paint the circuit board blue -- that should fix things for you! The darker the blue, the lower the cutoff voltage...
      (Sound crazy? Isn't expecting us to GUESS what the circuit entails in order to tell you how to modify it just as "crazy"? :< )
      Your question also lacks specificity -- just how MUCH lower do you want the cutoff voltage to be. And, does it need to be adjustable??
      A charger consists of a mechanism to deliver charge to the cell being charged AND a mechanism to monitor the state of charge (often by sensing cell voltage). There may be other provisions to enhance the charging (temperature monitoring, etc.).
      So, you need to know the level of integration for the charging IC to know if the two functions are independently available on the pins of the device.
      If it's all wired together "internally", then your only remedy is to make the cell appear to have a greater cell voltage than it actually does. I.e., ADD a voltage drop to that of the cell and pick that drop to match the amount of "lowering" that you want. E.g., a Ge diode in series will "trick" the charger into thinking the cell voltage is 0.3V greater than it actually is.
      [Hand-waving as there are other issues in the charger that can bias this decision -- like current flowing through the cell while the voltage is being sensed]
      Think more exactly about what you want and what information you can offer...
        Input voltage to the charger can be 110-220 AC, and I use 110V AC.
        It is hard to see the no. on the diodes so I better measure the voltages across them.
        When the charger is not charging:
        ZD2: 163.4V
        D3: 5.78V
        D4: 3.58V
        When the charger is charging a cell:
        ZD2: 150.4V
        D3: 7.3V
        D4: 4.32V
          D4: 3.58V
          D4: 4.32V
          Is this diode next to the battery terminals
          How much lower do you want to make the voltage
          9 PC LCD Monitor
          1 Dell Mother Board
            I can trace that D3 is connected to the positive battery terminal.
            I want to lower the stop charging voltage to 4.1V.
            Attached please find 2 more photos on the circuit board for your reference.
              Ok
              now you have to get the part number off of the diode and put a second one in series
              But depending on what type of diode it is it might need more than one
              The easiest way is to unsolder it from the board but make sure you know which end has the band end
              9 PC LCD Monitor
              1 Dell Mother Board
                Ok
                Thanks a lot. I will try that accordingly.
                  I'd say forget about changing the voltage. I think that zener will not affect the voltage at all, and the charger voltage reference and control is within the IC. Thus it will be quite difficult to be influenced externally unless you lie to the chip, but then you lose charge capabilities.
                  After studying my Baofeng's charger, I feel this charger is likewise a crap linear lithium ion charger...
                  ... but don't take my word for it until we find a datasheet.
                    Think about you might be right about this I could not find the right information for this chip
                    9 PC LCD Monitor
                    1 Dell Mother Board
                      I have some of them but never tried to modify one because the charging current is so low
                      500 milliamperes or might be a little bit more
                      9 PC LCD Monitor
                      1 Dell Mother Board
                        Yeah, my Baofeng charger is like 1A max but is package dissipation limited(!)... The chip is a SOIC8 and thus cannot dissipate much heat -- and thus I killed mine... hah.
                        I need to get another chip...or another charger. *sigh*
                          Thank you very much for all your comments.
                            That's a likely conclusion.
                            Yes, but without knowing the circuit topology, you can't determine if this is "hard-wired" in the controller, or not. E.g., the reference in an LM317 is "inside the chip" yet you can make a '317 act in all sorts of "adjustable" ways!
                            Of course, given that it's a ONE LAYER board, the OP could have taken the initiative to trace the foils and hacked together a crude schematic (even if he doesn't know what the components are and just draws each as a "two terminal box"). From that, it would be relatively easy to determine how much of the control is provided by "component selection" vs. hard-wired.
                            It depends on how you "lie". E.g., putting a PN junction in series with the battery offsets the cell voltage without interfering with charging. But, you really only get a couple of possible "offsets" with that approach. (a more "active" solution could get you a greater adjustment range)
                            Again, a crude schematic would tell you a lot...
                            It's likely a "smart charge controller" with two-step charge profile and some "smarts" to decide when the "battery" is toast (and, possibly, battery temperature monitoring). Again, much of that would be apparent from a schematic... perhaps the OP can find a BLIND MAN to trace the foils for him?
                              AH, without a datasheet this could be hard. No matter what, I think you risk blowing up your device if you change things. (most likely, killing the mosfet)
                              Honestly, if you wanted to use this as a learning experience I would find a charger with an IC I could get a datasheet on. Most of the time a 5$ charger off of ebay will have one of these chips. Cheap stuff likes to use ic's with good datasheets that have schematics in them, or so I have found. (Might be chinglish, but probably still ok.)
                              Well, beyond those conciderations, here is what I think you likely have:
                              1 switchmode power supply chip with a voltage programmed(either with Resistive divider/zener) to about the right voltage for a fully charged battery. From there, I think you have an overvoltage cuttoff using discreet components. I could be wrong on that, but you can make some pretty "ok" over and under voltage cuttoffs using a mosfet/transistor, a zener, and some resistors. But all of this is a guess, since we don't have a schematic.
                              “Men always seem to think about their
                              past before they die, as though they were
                              frantically searching for proof that they
                              truly lived.”
                              – Jet (Cowboy Bebop) -
                                Look here for info about your charger using PCB ZJ-3009-25
                                https://raspiblog.noblogs.org/post/2...ttery-charger/
                                IC: HT3582DM (HX-3H1227)
                                https://www.alldatasheet.com/view.jsp?Searchword=HT3582
                                The datasheet of the HOTCHIP HT3582DM is on Chinese and I have to use a Chinese to English Translator.
                                Here are some useful information from the datasheet:
                                - The HT3582DM is an internal reference voltage control chip universal charger with automatic battery polarity, short circuit protection, over temperature protection (of the chip).
                                -- Maximum charge current is 300~350 mA
                                -- Support for 0V rechargeable battery
                                -- Normal mode for three lights' and two lights mode or colorful lights mode.
                                -- No Load Voltage Minimum 4.15V, Typical 4.23V and Maximum is 4.30V
                                -- Saturation Voltage, Minimum 4.17V, Typical 4.25V and Max 4.32V
                                Pin 1 is the Battery Negative
                                Pin 2 is the Light 3
                                Pin 3 is the Light 2
                                Pin 4 is the Light 1
                                Pin 5 is the SW pin, function selection
                                Pin 6 is the GND
                                Pin 7 is the Battery Positive
                                Pin 8 is the Vdd (5~8 +Vin)
                                  how does the led operate ? like is it red then green or ?
                                    If it's something like the Baofeng charger, it's like green when idle, red when charging. Probably will light or blink if over temperature or shorted. It's all chinese to me, no clue...
                                    But I think this pretty much proves it, it will be very hard to change the voltage of this chip. Any takers? I would almost bet no takers here, even with the reference design circuit shown in that data sheet.
                                    IMHO the only way to change the voltage is replace the chip, pretty much... If someone forced me to modify the design to lower the voltage, I would require minimally one or two MOSFETs, few op amps maybe, another zener, and resistors to make an external reference to fake the voltage to the chip.
                                      The only "thing of value" is likely the case and the mechanism by which it mates with the cell being charged. Remove all of the electronics and deadbug a new charging circuit (of whatever characteristics and complexity are appropriate).
                                        Maybe this could help you
                                        https://www.youtube.com/watch?v=OU5WQTAtaUo&t=336s
