Toshiba Satellite c850 display
    Re: Toshiba Satellite c850 display
    I have a bios L855, same problem , no image intern or extern, i try bios, i make reballing to ati 216-0810028, i change the cpu, .....nothing !!! caps lock and num working.
    remains reballing all memorys, or SLJ8E ( BD82HM76 )
      ANY help ?
        Maybe HM76 need to be replaced?
          Anybody found the solution for these Toshiba L855?
            Maybe northbridge chipset needs reflow or replacing.
              I also change northbridge, nothing change. The machine is still in the same condition as i said in my old post.
                i have same problem to... board CAPS and NUM working, bios flash no change...
                reflow vga or pch = same, no effect
                any info on problem?
                Im Back... sort of...
                  hi i think it is gpu rams even you replace the vga chip will not work it is the gpu rams chips
                    But where is nuvoton npce and bq
                      reball gpu or change it
                        cccccccc
                          does anyone rectified the no display problem for toshiba C850 ?
                            hi,
                            i solved the issue its with amd gpu
                            changed the amd 216-0810028 GPU WITH AMD 216-0833000.
                            NOW ITS WORKING FINE.
                              enable the UEFI Boot use the external 100% ok
                                try to enable uma mode (it disable amd gpu and activate intel hd video )
                                just search uma in schematic and you will see components hat shall be enabled and disabled
                                  do you have schematic how to enable mode uma c855 or any link tutorial?
                                    Forget about it. You cannot do that. There is an uma version without discrete graphics. The discrete version is builded without processor igp power rail. Lvds connector gets its signals directly from dgpu...etc. There is no way to convert it to uma
                                      Thanks for the tip , it was my next step ... so not worth it ...
                                        Originally posted by dj_ricoh View Post
                                        cook the whole board!
                                        hi,
                                        if motherboard is not damaged..which coil we can remove to convert discrete to integrated?
                                        i have the same motherboard which was sent by innocentforeign.
                                        thanks
                                          Originally posted by ghaleb View Post
                                          hi,
                                          thanks
                                          That board can´t be converted from dsc(discrete) to uma. Missing some components to activate the integrated vga.
                                          Do vga chip reballing or change a new one
