hi had loads of help from this forum getting TVs back up and running but seem to be hitting a brick wall with this one.
Backlights failed before Xmas so ordered a new set and after replacing them and putting the set back together was delighted to see it work for 15 seconds only for the picture to flash on and off and a quick look round the back confirmed the backlights were flashing on and off
I have a steady 44v at +vled and a fluctuating 0v to 10v at -vled when the light start flashing, a steady Bl-on voltage and steady dim voltage.
If i disconnect 2 strings of leds the light stay on which leads me to believe an overcurrent problem.
I have now found a website that suggests increasing the rating of the 2 current sensor resistors which i believe are rated at .33ohms.and is a particular problem for this 715G6973 board.
My question is if anyone has come across a similar problem and done the same modification then by how much did they increase the resistor by
