SHARP LC-70UQ17U standby but no backlight or video =(
    Re: SHARP LC-70UQ17U standby but no backlight or video =(
    video there, most of them work in a similar manner, he's testing without dismantle at about the 5 minute mark, that test at 5 minutes do with tv unplugged, the tester will do the work: https://www.youtube.com/watch?v=Gkxm8jqqbQs
      You should also retest those Voltages you reported since there are so many errors as shown.
        Originally posted by anthony_c View Post
        I have the dreaded 2-5 blink code.
        which LED color you have the 2-5 blinking code ?? RED with GREEN or ONLY RED !!!!
        yours First post measurements all mysterious , maybe yours Digital meter battery low.. so .. post clear photos on yours power boards especially the socket label which goes to main boards.
          Ok, will follow and report back.
            Will do and report back @budm, its a bit hard being that the TV is so huge. I HAVE to test it with the board plugged into the TV right?
              Only blue, no other color. I will post clear photos for you tomorrow when I get back to the TV.
                Welp guys, I think I have bad news =(
                After spending so much time , I finally connected the backlight tester and it does seem that the panel is cracked. It was working fine while on the wall and sat in the same place since it was dropped of to me so I suppose it was cracked in transit. It makes sense because the guy said he wasnt getting any blinking only distorted picture when he took it off the wall.
                This sucks as I am pretty sure, originally this was a driver issue which I could have fixed by cutting out the tabs but now theres nothing that I can do =(
                Posting pictures shortly.
                  Here are the links to the images:
                    If indeed the panel is cracked, is it worth stripping it down for anything? Or should I just dump it?
