Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 05-05-2010, 07:50 PM   #1
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Need help to identify ELNA capacitors series
I've got a small hand-held LCD TV (TV-100 by Casio)
Someone has left the batteries in too long and they've leaked. Luckily the major damage seems only to the battery springs.
However 3 capacitors have come into contact with the battery acid and aren't looking too good.
They are ELNA and are yellow. They are also small (look 4mm by 8mm or so) and I have no idea what series they are. They are:
50v 4.7uF ELNA CE85C 9318 (H)
6.3v 47uF ELNA CE85C 9316 (H)
50v 1uF ELNA CE85C 9310 (H)
I guessed the series is either H or CE but neither of those show up on the ELNA website (I guess these capacitors are either too old or the series is not marked in the way I am expecting)
I've attached a photo in case it also helps.
Agent24 is offline   Reply With Quote
Old 05-06-2010, 05:17 AM   #2
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Default Re: Need help to identify ELNA capacitors series
93xx is probably date code [1993 and the week]
CE is the sleeve material [I think]
H is probably the tolerance [+/- 3%]
They are probably not low ESR.
Sometimes when a buyer orders enough or something special they'll do a custom run and they might not get a series marking. +/- 3% is pretty rare so that might be the case here.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 05-06-2010, 06:26 PM   #3
Agent24
I see dead caps
Agent24's Avatar
Sounds like your date code interpretation is right, The Casio TV-100 was made in 1993.
So I looked for an old version of the website and found this:
http://web.archive.org/web/199802121...om/ptable2.htm
Looks like these might be "RC2" series: 85C, small size and yellow sleeve - the description fits the bill anyway.
So they look like just standard capacitors but with small form factor. Can't see anything related to the (H) though.
Maybe they are RC2 series but with better tolerance than usual, as you said, a custom order.
Old 05-06-2010, 06:51 PM   #4
lehua011
Banned
lehua011 is offline   Reply With Quote
Old 05-06-2010, 07:40 PM   #5
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
Hmm, interesting. Where did you get this information?
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 05-06-2010, 08:06 PM   #6
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
Line Voltage: 120VAC 60Hz
Probably out his ass. I removed the spam for knock-off garbage handbags in his sig.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 05-06-2010, 08:42 PM   #7
370forlife
Large Marge
370forlife's Avatar
out his ass indeed.
Old 05-06-2010, 10:15 PM   #8
Topcat
The Boss Stooge
Topcat's Avatar
out his ass indeed.
I didn't even catch that he stole pcbonez's text, the post was reported to me as spam, and that's all I looked at. Atleast if he's going to rip off someone's info, he picked a good source.
Old 05-06-2010, 10:48 PM   #9
Agent24
I see dead caps
Agent24's Avatar
Old 05-07-2010, 06:48 AM   #10
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
veiled copycat spam.
kc8adu is offline   Reply With Quote
Old 05-08-2010, 06:06 AM   #11
ant3202
ant3202's Avatar
City & State: Singapore
My Country: Singapore
Line Voltage: 230V 50Hz
hahas... even a reply got copied and posted
ant3202 is offline   Reply With Quote
