I'm trying to fix a turntable that has a problem spinning up with out help, but not every time, sometimes it does fine on it's own. It has a brushless slotless motor, and some have mentioned It might just need a good cleaning/lubing. Since getting to all the levers in this TT requires removing the tonearm, and I'm not quite sure of my soldering skills to deal with those tiny little wires, I thought I might take a stab at replacing caps 1st. Plus if I understand the service manual correctly, it doesn't seem like any of the other levers should prevent the motor from spinning up.
Anyway, the strobe light also wavers back and forth when set to proper speed, which the manual says can be normal due to power fluctuations, but I have an identical TT that doesn't do it so I thought I'd start with the power supply caps.
In the attached picture, the small cap has a little "shield" at the top of the cap with no text in it... the larger cap behind it has the same shield, but contains the text "Nippon Chemi-con".
Am I correct that that shield is their logo? And these are both by the same manufacturer? Also, I noticed they still have a website. If I am able to find caps with the same values printed on the caps on the site, can I be confident that the unprinted values (ripple current, etc...) will be close enough or the same? It seems like it depends on the application as to how close you need to be on the specs on caps, at least from what I've seen so far.
anyway, here's the pic:
