Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 01-25-2018, 01:57 AM   #1
rookieme
City & State: Athens
My Country: Greece
I'm a: Knowledge Seeker
Default fake desoldering wick
I'd like to inform the forum that lately when I try to buy desoldering wick from China [either via ebay or aliexpress] I'm receiving fakes that are not made from copper.
If you are having trouble when you are using your wick and it doesn't conducts heat maybe you get fooled too.
A simple test is with a magnet.
Copper doesn't get stuck at a magnet but these shity ones do get magnetized.
Also they are tougher than copper and cannot get chopped easily and can harm your tools.
Luckily so far I'm getting my money back at these cases after opening a dispute.
The affected brand is gootwick and so I'll try other brand to see the results.
rookieme is offline   Reply With Quote
Old 01-25-2018, 02:25 AM   #2
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Default Re: fake desoldering wick
Why don't you buy some genuine Chemtronics braid from RS ?
http://gr.rsdelivers.com/productlist...ily=11992&tag=
diif is offline   Reply With Quote
Old 01-25-2018, 02:37 AM   #3
rookieme
My Country: Greece
Nice one but it seems overpriced!
Seems to be the best quallity according its price though.
Old 01-25-2018, 07:16 AM   #4
diif
My Country: England
Compared to fake Gootwick, yes it will seem a little pricey.
The first time you use it though, you will realise it's cheap.
Old 01-25-2018, 07:55 AM   #5
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
spirig wick is good.
stj is offline   Reply With Quote
Old 01-25-2018, 01:20 PM   #6
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
+10, it is better to use good stuff instead of damaging the board with cheaply made stuff.
__________________
budm is offline   Reply With Quote
Old 01-25-2018, 04:30 PM   #7
petehall347
City & State: worcester
My Country: United Kingdom
try adding flux
petehall347 is offline   Reply With Quote
Old 01-25-2018, 08:39 PM   #8
lti
lti's Avatar
City & State: Windsor, Colorado
My Country: United States
I'm a: Hobbyist Tech
Quote:
Originally Posted by petehall347 View Post
try adding flux
That won't help if the wick is made of copper-colored steel.
lti is offline   Reply With Quote
Old 01-26-2018, 12:41 AM   #9
rookieme
My Country: Greece
Quote:
That is for sure, I have tested adding flux and rising temperature with bad results only.
The fact is that this situation happened after summer as before I could buy cheep wick and worked well as it was copper.
Old 01-26-2018, 11:49 AM   #10
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
Cant say I have had any problems with Goatwick I obtained a couple from Uk sellers then imported a quantity from China, both seem to perform the same and both are copper as far as I can tell. That said I rarely use the stuff anyhow and quite a lot of the work I do it would not work with anyway, through hole plated with heavy ground-planes etc, as though with most soldering processes adding good quality flux helps. That said for what I charge for rework and repair the Chemtronics braid seems more than reasonable, might try some.
llonen is offline   Reply With Quote
Old 02-06-2018, 11:41 PM   #11
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I have never tried the stuff from eBay. Now that you mention this, I doubt I will.
I have never actually tried the expensive Goot ones. Jaycar's cheap wick has worked well enough for me so far that I didn't see the point.
__________________
-David VanHorn
Agent24 is offline   Reply With Quote
Old 02-07-2018, 01:43 AM   #12
stj
stj's Avatar
a friend used to make his own,
stripping old tv antenna cable and running it through a pot of flux & ipa!!
Old 02-10-2018, 01:10 AM   #13
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Have used Goot Wick in the past and it was decent, but have moved to using Chemtronics exclusively for a good while now. It ain't cheap, but the weave is a lot tighter than Goot Wick so you use less for the same job.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 02-10-2018, 06:49 PM   #14
llonen
Have thus tried the chemtronics stuff for a while now and don't seem to notice any significant difference other than perhaps the weave, I too used to make my own de-soldering wick
Old 02-10-2018, 10:08 PM   #15
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
Line Voltage: 120VAC 60Hz
For me I've only ever used (successfully) Chemwick and MG Chemicals. The former seems to be a hair better but both do the job well. Cheap crap, I've used on occasion and I will say, it is indeed shit, even when they do use real copper.
__________________
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 02-28-2018, 03:54 AM   #16
dellxps15
City & State: Italy
My Country: italy
i use goot wick that buy from china. when i ask for them, i got a price list like this:
1$ for a fake, 1.5$ for a good fake, 2.7$ for a genuine japan.
i went always for the original and they are really good. i use the cp2015 2mm wide and ddesolder very good when applied the proper amount of flux.
before that, i got chemtronics from a local shop. got them for 2.5€, but now they havent them annymore and got some very very bad quality ones, so i still keep getting lots of that goot wick from china on each bga ic order i make.
dellxps15 is offline   Reply With Quote
Old 03-13-2018, 05:48 AM   #17
lax luthier
lax luthier's Avatar
City & State: Santa Barbara California
My Country: USA
I don't know if it's fake, but I bought ten rolls of "Solder-Wick" branded braid from All Electronics, which did not work. Could be stale?
Then one day recently I had an idea to soak it in acetone to remove the old flux, which it did. But also rendered was some nasty green stuff (copper oxide?)
After flushing the wick thoroughly it became nice and shiny as well as much more flexible and open-weaved. Now when dipped in some Kester liguid rosin flux it works perfectly.
Regards, "lax"
lax luthier is offline   Reply With Quote
Old 03-13-2018, 08:14 AM   #18
stj
stj's Avatar
the "nasty green stuff" may have been the old flux.
Old 03-17-2018, 10:00 PM   #19
lax luthier
My Country: USA
Quote:
I don't think so, the flux turned the solvent an amber color, pretty typical for rosin flux.
Well the good news is the treatment was successful. Could well be a remedy for
some of the other braid product cited earlier.
Regards, - L -
Old 03-18-2018, 04:38 AM   #20
stj
stj's Avatar
plain rosin wont work with lead-free solder very well.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
