Hi all, ok im getting more and more knowledge from this forum and i have to say i highly appreciate about all the inputs and outputs out of this forum based on everyone's feedback about caps. Thank you very much for that. I just need to learn a bit more about caps.
Ok example. 220uf 450v cap. Lets take from the microfarad value. Original value of the cap is 220uf, but upon using various testers and meters, it shows
Cap - 240.8 UF
ESR - 0.16 Ohm
Ok so what i need to know is, the cap uf should be + or - 10% right? And if its above than that then its gone, correct? I'm not assuming, im still learning. Just need some guidance in understanding caps more deeper. So is the above reading for the cap is faulty or its in fine range?
Cap - 240.8 UF
ESR - 0.16 Ohm
