**I need to get to my desktop to upload a few pictures. Stay tuned **
Model: Toshiba 50L3400U
Manufacture date: 2014 Feb.
Original complaint: Original owner said the TV blinks after about 15 minutes of watching it. All HDMI inputs exhibit this behavior. Haven't had a chance to verify if this occurs on the TV ANT connection, or the Composite inputs yet.
Boards:
Power supply board: FSP107-3FS03 (PK101W0350I)
Main board:
Diagnostic Notes:
Backlight voltage are 55V nominal according to the power supply silk screen.
I reset the TV to defaults and disabled the auto brightness function of the TV.
When the dynamic brightness control is enabled, the screen blinks more/less depending on the brightness of my room.
The blinking frequency increases as you manually adjust the TV brightness.
I may just leave the brightness at 60. It's plenty bright for this room, but does anyone have any suggestions?
Thank you,
Thomas
Boards:
Main board:
Diagnostic Notes:
- No bulged caps found from visual inspection.
- Backlight completely shuts off and then turns back on (I confirmed it wasn't the video source since you can see the backlight turn off through the holes on the back of the panel)
- All the connectors and ribbon cables are seated; and re-seated to double check.
- The power supply board generates a steady 12V2, 5V1 to the main board.
- The PW_ON signal is a steady 3.3V
- BL_ON signal is a steady 3.3V from the main board. I'll grab my portable oscilloscope and verify it's not turning off for a small toff time.
- Vled1 measured = 55.8V
- Vled2 measured = 55.8V
- Vled3 measured = 55.8V
- Vled4 measured = 55.8V
- At backlight=100%, it blinks about 3-4 times per second.
- Backing the backlight down to 75 makes it blink slower to ~1 time per second
- Backing it down to 60 seems to make the issue go away (at least in the last few minutes of observing the TV)
Thank you,
Thomas
