Lenovo IdeaPad s340 burned motherboard ?
    Re: Lenovo IdeaPad s340 burned motherboard ?
    Originally posted by ktmmotocross View Post
    just measure rezistance on both side of capacitors to ground.
    if u dont have ram inserted and laptor start, than u must have ram on board, so try to remove inserted ram
    check if u have 1.2V on pl502
    I just remember that this pc has 4gb of ram integrated on the motherboard (i don't know where), so you are right.
    i'll check the other voltage and components
      i just find out that 1 capacitor was shorted, so i solder it again and........ it turn on!!!!!
      But There is a big problem: the temperature!
      When i turn the pc on, the fan started normally and after 1 sec it stop.
      I waited until the login screen (about 4 seconds) and the ssd and the black heatsink become very hot.
      What can i do?
        No one know?
          did it turn off from heat when u let it run?
            I turned it off manually because it got too hot...
            i have a bit of fear to burn it totally
              dont havefear. if it gets too hot it shut down itself.
              maybe it is programmed to start fan when hot. chips can withstand heat that burn your finger normally
                do i have to let it on and see what happen?
                Do i risk to burn everything?
                  sorry, i just read you replay... i hope that it's not burn the temperature sensor or something like that and it wont turn off
                    no. every big chip/cpu, GPU, NB/ have inside sensor
                    check if u dont have bend heatpipe
                      In the first image you can see the heatpipe in red and the very hot point in green.
                      Now i'm waiting for a capacimeter from amazon to measure the capacitor (do you know some other way to measure with a normal multimeter?) because.... i burn the first one near the pl501....
                      I need another capacitor (the one in the second image)
                      Every time a move sometring, the situation gets worse
                        that green points is GPU, CPU and SSD controller. offcourse it is hot. just check if side of heatpipe near fan gets warmer
                        u dont need capacitor meter. just replace all three capacitors. it is cheaper
                          can i replace che three capacitor with some other random capacitor of the same size? (like i did with the PL501)
                          do i need to check some value?
                            u have schematic with values
                              yep but i can't measure che capacity of the other capacitor (because i'll take the capacitor from another board but i can't measure their value)
                              I'm sorry for making you waste all this time but.... can you tell me the value?
                              I don't know how to find it in the schematics.
                              I feel so stupid, but i'm learning!
                                on board u see that capacitors is connected just after PL502. in schematics u see that it is 22u /microfarrads/ 6.3V
                                  thanks for the replay, I didn't think those were the capacitors because they are 6 in the schematic (and i have only 3 capacitors).
                                  but ok,i'll find the capacitors and relace them!
                                    oh my god. dont u think that the other three can be on other place on board? it is schematic not boardview
                                    if u want to see others three find boardview
                                      I know the other capacitors may be elsewhere, but I wasn't sure...
                                      Now l'am looking for capacitors on other motherboards
                                        i'm here again with some update: i can't find anywhere that capacitor 22 microfarrads, 6.3V), i check the schematics of 10 old motherboard and.....nothing.
                                        So i try something (maybe very stupid, i don't know): i turn it on with 2 capacitors (not 3) and it seems to be working well.
                                        i check the temperature:
                                        -ssd m2: 66/68 degrees Celsius (misured with Hard Disk Sentinel)
                                        -CPU: core0 -> 57 degrees Celsius
                                        core1 -> 59 degrees Celsius
                                        core2 -> 72 degrees Celsius
                                        core3 -> 56 degrees Celsius
                                        (misured with speedFan).
                                        I'm worried about the ssd and the core2...
                                        The other temperature are normal?
                                        What do you think?
                                          What do you think?
                                          all cores have literallly same temp because it is on same chip. its just bad reading. that capacitors must not be there but u can have some instability so better add capacitors with same size.
