http://pg.photos.yahoo.com/ph/nsx29c...?.dir=/4d64scd
hmmm... img attach not working.
This Elna looks bulging. As far as i can see it's general purpose and surface mount so recap is impossible. This is very rare stuff. hmm.
This cap is on a Elsa X1300 video card pci-e. Very recent stuff but according to date code. The elna cap is manufactured in 2004 which is very old stuff. I have no clue why it was used. I thought most computer stuff uses low esr stuff not general purpose.
By the way, the system is running a zippy powersupply with chemicon ky caps. so i am confident that this must be some sort of manufacture defect or expired capacitor (not likely but i heard caps are good for 2yrs shelf life.)
Even the best capacitors are not immune from failure...
its no big deal to replace that cap.i replace sometimes 50 tiny ones at a time in old sony camcorders.
10 minute job for me to replace that one and all others like it.
It's probably a misapplication of a general-purpose, 85c cap instead of a low-ESR, 105c cap. Even Pannies and Rubies will fail quickly in such situations.
There are probably no better caps than Elna R** for most small-signal audio use. For large caps in the Power Amp, Elna RJH works fine - but Panny FCs or Nichicon P* probably have a small edge for high dynamic-range performance. The differences are slight and highly subjective.
Black Gates, Cerafines, etc. are probably wasted money, but if you've got a well-heeled customer who wants them, you might as well take the money first, and skip the common-sense explanations.
I consider Elna as good cap. They are long in business and have good Q/S.
And those SMD typs are very easy to desolder. Have replaced alot of them from a charging unit for Motorola GP900. Never needed something else than a soldering iron and something to pick up the hot cap.
