I have a nicd powered 18 volt pipe cutter. I found it in the street one day (in its box with 2 batts and a charger) and though I do not have much use for it, I do use it occasionally. However the batteries died and I did not want to spend the money to get new batteries for something that I hardly use. So I decided to hard wire it.
I have a PILE of AC adapters and found one for an HP laptop that is 19 volts and (supposedly) 7.1 amps. However when I hard wired it to the pipe cutter it barely could move it and the light would go out on the AC adapter. Is this because it is not running at 21.75 volts that a fully charged battery pack puts out? or is the AC adapter lying about its amp rating?
correct me if I am wrong but most nicd battery packs are are only around 1.3 to 2.2 amp hours.
