Anyone know of a good circuit board repair company that can fix a board without a schematic or board view?
Robosapein V2 Bot PCB repair wanted
Re: PCB repair wanted
Have to assume it's the robot. but if it's visibly damaged it usually can be done without schematic. If it's not visibly damaged and there's no obvious signs (shorts, etc.) then it gets mighty hard without a schematic and repair costs increases rapidly due to debug time...of which a reverse engineered schematic may be needed/generated, which may end up above the cost of a new unit...
It's a circuit board out of a discontinued vintage Robosapein V2 Bot I'm Trying to repair. Board seems to be dead due to cheap wire insulation. It flakes and falls off, then shorts something out in all units. Bot is not working after being rewired. And I can not find the schematic or board views for it anywhere online. There appears to be a burn mark on the board which is circled in the attached photo. Although it could also be a blue company test check mark covered in flux, placed after manufacturer tested it. Not sure. Looking for someone to check over the board and fix it if needed.
Originally posted by stj View Postthats vague, what is it?
got any pictures?
fault description?
most things are repaired without a schematic.
Re: Robosapein V2 Bot PCB repair wanted
The glue on the board has the characteristics of rubber or contact cement. It stretches a lot before it begins to peel off. Don't want to scratch at it too hard so as to not damage any traces on it. I have found out that Mineral Spirits will help remove rubber cement. Will using it, sparingly, damage the coatings or other parts on the board?
BTW You have been the greatest help to me so far.
Hi
I dabbed on Isopropyl alcohol (didn't soak board in it) to soften the glue and carefully picked all of it off. Bot still not working. Attention now is on the Main board marked with EW and numbered (6028-1G). Good call BTW. The mark on the board was made with a marker, not a burn mark. Shouldn't there be a copy of the schematic and board views for these boards out there somewhere?
Thanks again for all your help
boardview is just a mac thing,
schematics are down to the maker to share or not.
that board you cleaned doesnt really need one,
it's clearly just a repeating pattern of transister switch circuits presumably to let the logic signals drive the motors.
if it failed it would only effect one motor
Originally posted by stj View Posti dont think meth-spirit will damage anything, but i know acetone will.
test the spirit to see if it damages the connectors though.
Look closely at all the soldering joints for ghosting rings around the the bottom of the joints or a lot of flux or corrosion on the soldering joints or cracked soldering joints ( I see some soldering joints that look very ? able
I would look at under a magnifying glass for what I have above )
After that then start looking up part numbers and see what they are and checking them for functionality
Both of them are very time consuming projects
I once fixed a battery operated magnet plate for steal plate crane lifting device that the hole board had corrected soldering joints I had resolder the entire board and did manage to get the device to work correctly again but it took several days to do this
The small red board on the main part of circuit board looks like it is some type of micro controller which could be damaged by the shorting of wires hopefully not
Please post a picture of power supply board as well because the issue might be on this board as wellLast edited by sam_sam_sam; 12-09-2022, 07:36 PM.9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
Originally posted by lotas View PostNo, these are the remains of rosin when this module was soldered manually."The one who says it cannot be done should never interrupt the one who is doing it."
