I have a Sharp LC-60LE600U TV. So far I haven't found a service manual for it.
The LED indicator will light up white and then turn off after about 10 seconds.
I noticed when probing the voltages right before the indicator would go off there would be a short buzz and I could see the LEDs light up for a second at the edge of the panel.
PIN VOLTAGE ON VOLTAGE AFTER LED TURNS OFF
PD1 – PNL12V 12V 0V
PD2 – PNL12V 12V 0V
PD3 – GND 0V 0V
PD4 – GND 0V 0V
PD5 – UR13.2V 0V 0V
PD6 - UR13.2V 13.2V 0V
PD7 – UR13.2V (N/C) 0V 0V
PD8 – UR13.2V (N/C) 0V 0V
PD9 – GND 0V 0V
PD10 – GND 0V 0V
PD11 – GND 0V 0V
PD12 – GND (N/C) 0V 0V
PD13 – AC_DET 3.3V 2.5V
PD14 – PS_ON 2.08V 0V
PD15 – BU5V 5.04V 5.04V
PD16 – PNL_POW 0V 0V
PD17 – PWN1 0V 0V
PD18 - N/C 0V 0V
PD19 – DIMMER 0V 0V
PD20 – N/C 0V 0V
PD21 – OFL (N/C) 0V 0V
PD22 – ERROR 3.29V 0V
PD23 – PWM2 (N/C) 0V 0V
PD23 – STB 0V 0V
L1-1 LED1+ 11V
L1-3 LED1- 83V
L1-5 LED2+ 11V
L1-7 LED2- 83V
L1-9 LED3+ 11V
L1-11 LED3- 76V
L1-13 LED4+ 11V
L1-15 LED4- 83V
I tired powering it one with one of the cables disconnected from the TCON board. With either ribbon cable disconnected the LED would go out in just a couple seconds. I unplugged the LED power connector from the power board and when turning on the LED was flashing. I didn't appear to have a pattern other than just a steady blink on and off.
I'm leaning towards maybe a bad power board but I am not sure. I want to be more sure before I buy a power board or any other board.
Thanks for the help.
PD1 – PNL12V 12V 0V
PD2 – PNL12V 12V 0V
PD3 – GND 0V 0V
PD4 – GND 0V 0V
PD5 – UR13.2V 0V 0V
PD9 – GND 0V 0V
PD10 – GND 0V 0V
PD11 – GND 0V 0V
PD17 – PWN1 0V 0V
PD18 - N/C 0V 0V
PD19 – DIMMER 0V 0V
PD20 – N/C 0V 0V
PD23 – STB 0V 0V
L1-1 LED1+ 11V
L1-3 LED1- 83V
L1-5 LED2+ 11V
L1-7 LED2- 83V
L1-9 LED3+ 11V
L1-11 LED3- 76V
L1-13 LED4+ 11V
L1-15 LED4- 83V
