Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Thread Tools Display Modes
Old 11-25-2022, 06:58 AM   #21
Strolch
City & State: Aurich Niedersachsen
My Country: Deutschland
Line Voltage: 230V 50Hz
I'm a: Knowledge Seeker
Default Re: Macbook A1990 820-01041-A Dark Display
ok, good that you are here. Thx
Strolch is offline   Reply With Quote
Old 11-27-2022, 07:59 AM   #22
Strolch
Hi mon2,
i have
R8401 12,55Volts
C8401 Pin1= 0,04Volts Pin2= 12,55Volts
Q8400 Pin 3+4= 12,55Volts
R8442 Pin1= 0,0006 Volts
Old 11-27-2022, 08:31 AM   #23
mon2
mon2's Avatar
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
With R8442 at 0v, the backlight circuit is not being enabled.
Check the lid switch voltage to ground. This hall effect switch is inside the trackpad and often causes problems. With no power, also confirm that the interface cable contacts are clean and properly seated. IPA and a cotton swab are great to clean the cable contacts. If the logic board believes the lid is closed, the backlight will remain off.
mon2 is online now   Reply With Quote
Old 11-27-2022, 09:10 AM   #24
Strolch
ok, but I took the measurements with the logic board removed. The measuring points are all on the back.
Old 11-27-2022, 10:54 AM   #25
mon2
mon2's Avatar
My Country: Canada
Ok. See attached.
Measure the voltage to ground of the IPD_LID_OPEN signal.
Old 11-27-2022, 11:31 AM   #26
Strolch
I have 1,794Volts at Pin 4 U4802. And There are solder balls on the U4802 at pin 4 and pin 3
Old 11-27-2022, 11:44 AM   #27
mon2
mon2's Avatar
My Country: Canada
LID sensor is OK.
What is the voltage to ground of:
I2C_DISP_SCL
I2C_DISP_SDA
PP1V8_S5_GPIOX_R ; power to the MUX (and the (tech) people)
PP3V3_S5_GPIOX_R
The above are used to deal with the display (U9801) and also the backlight enable signal.
PS: Have to check out for a few hours for the usual grocery shopping. Purchased some new security cameras for the business and the NEXT day they dropped the price. Really?? Price adjustment time
Old 11-27-2022, 12:24 PM   #28
Strolch
Ohh;-)
I2C_DISP_SCL = 1,79Volts
I2C_DISP_SDA = 1,79Volts
PP1V8_S5_GPIOX_R = 1,79Volts
PP3V3_S5_GPIOX_R = 3,34Volts
Old 11-27-2022, 07:21 PM   #29
mon2
mon2's Avatar
My Country: Canada
With no power to the board, meter in resistance mode, check the resistance across R8401.
It should be ~80k ohms.
Old 11-28-2022, 03:57 AM   #30
Strolch
yes 80,42k
Old 11-28-2022, 02:48 PM   #31
Strolch
What else can I do? Another idea? br
Old 11-29-2022, 06:09 AM   #32
mon2
mon2's Avatar
My Country: Canada
Does this display function on another logic board?
The logic board works with an external monitor?
This model is impacted by flexgate so the fault may be broken interface cabling on the display assembly.
https://youtu.be/k0xZe_4D8C0
Old 11-29-2022, 03:53 PM   #33
Strolch
Yes, everything is ok on the external monitor! I just bought a same A1990 with defective board. Since the display is intact. I'll put my board there!
Old 11-29-2022, 03:56 PM   #34
Strolch
No Flexgate, then I rather think that the board got some liquid from the display. It's also getting very warm, I just noticed.
Old 11-29-2022, 06:26 PM   #35
Strolch
Hi, its the Display!! I found another A1990 here! and the display is intact. It works! So the board is defective from the display! Can you also buy the board?
Old 11-29-2022, 07:27 PM   #36
mon2
mon2's Avatar
My Country: Canada
That is good news ☺️
For knowledge, watch this video where only the lcd is replaced for a macbook. This is a lower cost option but then is a longer servicing time for the procedure.
https://youtu.be/I_kcMyhwZls
Do read the comments as well. Personally is on my things to do list but first need to fix up our company and take legal action against the guilty one. Lawyer meetings this week.
Old 11-29-2022, 07:37 PM   #37
Strolch
Can I also buy the display board? Then you don't have to replace the display if only the board is defective!
Old 11-30-2022, 06:52 AM   #38
mon2
mon2's Avatar
My Country: Canada
Have not seen only tcon board repair but ask the lcd vendors on AliExpress.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
