Bios password remove 850 G3 HP
    Please help me remove the password.I uploaded the clean 16mb file readed from my programmer!I tried some 850 G3 no password from other posts in here but i got only capslock flashing and no post! I think i may need my own dump file to be edited! Thanks!
    Re: Bios password remove 850 G3 HP
    Try this and post result.
    Good Luck
      if the above file does not work, try using this file..
      goodluck
        Hallo
        Plaease can you help me with remove password for Hp ElliteBook 850 G3 - 2016.
        Motherboard number 6050A2892401-MB-A01 .
          HP 850 G3 Bios password
          If someone could clean or even better tell me what to clear I would be very grateful. Thanks.
          Motherboard Rev 3.0 918312-601
            Re: HP 850 G3 Bios clean request
            what is your problem?? slow boot?
            first you can clean your ME region...
            check this thread...
            https://www.badcaps.net/forum/showthread.php?t=74160
              Bios is locked
              Also there are two chips so hopefully I pulled the correct one
                Bios is locked
                I have seen that your file doesn't seem to be locked by adminpassword, maybe locked by intel computrace?
                  Yes that is correct. Sorry about that its been a long day.
                    So you mean locked by computrace? maybe you can try to clean your me region and disabling tpm,, try link winraid above thread...
                    but you must provide 2nd bios(8MB)... better you read 2nd chip too...
                      Yes its locked. Ok I will dump 2nd bios and post. Thanks.
                        before you pulled 2nd chip try this...
                          Lol **** too late
                          I'll post 2nd dump shortly.
                          Btw I desolder the chips to dump so little sketchy
                            Lol **** too late
                            sorry...
                              sorry...
                              attached
                                Power light is flashing orange after write. I'll recheck my points to make sure.
                                well re aligned chip and now got white and orange blinky lights so that's progress lmao.
                                  not sure what to do from here. Are the images I took good?
                                    850 G3 password remove
                                    hi i need help whit mine HP 850 g3 could anyone tell me what lines to edit in hex so that the password is removed
                                    ore could you help me remove the password from my bios file
                                    thank you
                                      Re: 850 G3 password remove
                                      Here is clear me dump
                                        ty you very much
                                        found the blocks to remove to delete the password just before you uploaded
                                        Quote:
                                        Originally Posted by medln25 View Post
                                        issue fixed. fffed those blocks :
                                        72a000 to 75c000
                                        b10064 to b50000
