POST clk LED question ?
    Guys,
    Can I see 33MHz from clk LED pin on POST diagnostic board connected on PCI ?
    Or the value is something else beside 33MHz...
    How can I know if there's clock on my motherboard ?
    It says on the manual it must be on...
    but sometimes I saw it's off and motherboard is running properly...
    and in different POST it's blinking and motherboard is running ok...
    I saw one, it's not completely on or off.....and the motherboard is not doing anything...so isn't there clock generated from clock generator ?
    I've checked the crystal of clock generator, it's ok, but I'm not sure if the chip is doing the job....and I can't see which pin is outputing the clock for CPU/PCI...since there's no datasheet for that chip...
    Any clues ?
    Cheers...
    Re: POST clk LED question ?
    Probably, I can test from pin B2 and B16 with scope ?
    http://pinouts.ru/Slots/PCI_pinout.shtml
