asus n551j-i7 it turns on as soon as I connect the charger
    hello, this pc as soon as you connect the charger the wlan leds turn on, power-on button and on, the fan at the beginning turns in steps then after 10 sec it turns continuously at max, I thought about the corrupted bios but I have doubts about the gpu or cpu, has anyone had a problem like this? what do you think?
    thanks
    Re: asus n551j-i7 it turns on as soon as I connect the charger
    check rtc section
    check by removing lan ic
      Do you get display?? Does the mb has a separate RTC cell or it is inbuilt in backup battery??
        the 3v lithium battery is on the main board
        no display
          I forgot to mention that the tensions are all there
            D5801/D5803/D5804-Check PWRGD signals on them.
              hello friends, the asus n551j laptop does not have a reaction at all, when the charging is connected to the BIOS, 3.0 volts is present and immediately goes out. please help me, the brain is not enough.
                Check rtc crystal is generating clock 32.768khz
                With multimeter crystal will measure around o.40 to o.30 voltage and at output 0.34
                Voltage on bios pin comes after turning on in some laptops
                  I have a similar issue with my n550jx (CPU and GPU also heating up after powering on)
                  If I hold the power button for 8 seconds then it turns off for 1 second but turns right on after 1 second.
