Lenovo s400 - no video on lcd only backlight, on external is ok
    Hello.
    Have this Lenovo s400 that have no video on lcd only backlight. on external is everything ok. i try to measure voltage pins and only voltage that looks off is +LCDVDD_CONN which is 0.4V. when i remove L29 i have 3,12V on first pin and 0.4 on second pin.
    i have board rev. 1.0 and schematic is rev 0.1
    any hints?
    Re: Lenovo s400 - no video on lcd only backlight, on external is ok
    What's the resistance to ground on +LCDVDD_CONN with and without LCD connected? And resistance across L29?
      4.4kohm with and 200kohm without lcd
        i think you need to test a good panel. my opinion need to replace. respect to you my friend.
        it is good to repair for experience.
        well maybe the TCon. maybe some capacitor near or filter caps have leak.
        wait. need to check also the IC. i dont know what brand. can you send a picture here. to identify
          removed both capacitors after coil L29 but nothing changed
          replaced panel and cable, but still the same
            Have you tried to replace Q72?
              What model number is the panel , is it n140bge-lb2
                just jumped that q72 and displey start to show screen. thank u guys. now i replace him
                  remove the LVDS cable from the motherboard connector, start the laptop and measure the voltages on the plug, if ok the problem is the cable or display ...
