Samsung PS-42C96HD DEAD
    I'm working on a SAMSUNG PS-42C96HD:
    TV dead! Not even a standby voltage!
    POWER BOARD:
    VDD on pin4 of VIPer22A (SMPS primary switcher) is ZERO vollt(s). In fact ZDB803 is short (overheated I guess!?)
    Help needed:
    -- value of Zener ZDB803
    -- typical value of VDD
    -- service manual of this TVC...(at least the SMPS cicuit:..)
    -- What could be the original cause of this short??
    Thanks a lot...
    Re: Samsung PS-42C96HD DEAD
    What's the PSU part number?
      BN44-00161A part #?
        1N5425B , 15V 1/2W zener
        I'm thinking Tom's number will be correct, so here's a schematic. I think it covers 42 and 50"
          Thanks guys...the problem is solved:
          Indeed the ZENER must be a "15 to 30" volts. the ref. on the diode is gone(from heat).
          (although the schematic is not exactly the same)
          The one in the attached file (special thanks to tw2005) indicates 2 15V ZENERS 1N5245B in series, while in the TV I'm working on there is only one.(I think this could be annother factor of overheat):
          I put 2 10V zeners in series and everything is OKKK. The TV became ALIVE again. With these 2 ZENERS in series: no more overheat & I got exactly 17.4 V on PIN 4 of VIPer22A. That should be OK. 5.1v for sdby is back again ...TV works perfectly.
          Also RB830 is 1ohm 1/2 w not 2.2 as in the schematic.
            Probably why the part number for PSU would be handy to locate the right schematic if it's out there.
              Yes you're right...In fact I wrote all the info. of the power board on a sheet of paper...I closed the TV ... I left the sheet in my workshop...I'm now dead tired at home...
              That will be for TOMORRROW...
              Thanks anyway.
                This is all the info. I can read on the back cover of the 42" SAMSUNG TV (I mentioned earlier):
                PLASMA DISPLAY
                Model: PS-42C96HD
                Model code: PS42C96HDX/XEC
                Type No.: CA42C9
                AC 220-240V 60Hz 380W
                Manufactured: January 2008
                Made in SLOVAKIA
                As for the PSU part ref:
                DYP-42W2 PLUS
                Rev 1.0
                Code: BN44-00194A
                Input: 200-240VAC
                50/60HZ 480W
                Now if you can help find the schematic of this power supply unit, I would be very thankful. Although the tv is repared, I would like know the exact value of the Zerner that caused the problem, & keep a copy for future ref. Thanks.
                  Top result
                  http://www.tgohome.com/ServiceManual...&Search=Submit
                    OK OK ...
                    Thanks so much TOM66!! It's a library...
                      hello this is my first post , i have just inherited one of these sets and i am having problems .
                      No sound . no vision.
                      after power is connected blue light on front power switch solid then when pressed flashes four times then goes out.
                      Powerboard outputting respectable voltages without x and y boards connected.
                      Re-connect x and y boards power on Vs dissappears to zero Va still present at 6ovdc.
                      Disconnect x board with just y board connected then power on Vs is there at about 201 vdc.
                      Any ideas , I suspect x -board is poorly.
                        Xsus is dead then
                          Originally posted by ReeceyBurger123 View Post
                          Xsus is dead then
                          I thought so , many thanks . I have another board on the way.
                            before you swap the x-sus, did you do any tests?
                            how about the y-sus? have u checked if there's a short between Vs and GND on connector CN5004. also check transistors Q5001 and Q5007.
                              Ok latest update on the situation , new board arrived fitted turned on TV.
                              Had sound still no vision shut down tv went for some food came back turned on no Power!!!
                              No click from power board . Vs and value were always low thought it was my meter not being accurate enough Vs was 199/200 Va 60 / 61. Also will check those points mentioned in above post . Thanks.
