Do I need an exorcist?!
    Gigabyte GA-M51SME-S2. Few CHemi-Cons already bulged, did complete recap but input VRM (Rubycons) and one 470 uF/16 V (Nichicon).
    OK, so when I finally assembled whole computer (board tested off course independently, turned on so it looked like its OK), after like 10 minutes it suddenly turned off itself. I even managed to see screen of XP shutting down so it recivede some signal.
    Since than, its like obsessed with evil. It turns itself on and off randomly, sometimes even after couple if minutes to turn off right away again. What the hell?! There is no obvious short, swapping processor and erasing CMOS did not help.
    ADD// got new name for it: syndrom of Gigabyte evil obsession! Already e-mailed that to our local GB PR
    Well, now it is in lasta stadium, not even POST card talks to me, I guess I will have to scramble it and say some not just nice news to the girl
    Re: Do I need an exorcist?!
    Short between layers of the PCB that manifests only when that area heats up?
    Gigabyte recently made an announcement that they're using a new pcb material where the fiber strands are more densely packed, because it makes them less sensitive to humidity.
    They were saying in a press release that they got larger than average returns from India and other countries where the humidity is a bigger factor and when they checked the boards, there were shorts between layers of the pcb due to this.
      That's what my Acer TravelMate 4200 laptop does with dying battery. I think the battery is bad.
      Because no problem with an HP AC adapter.
      And with a desktop, I would check the ATX power switch.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      16 GB AData XPG Spectrix D41
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        Today it even fired up, but still the same behaviour. I have the boad on ground, no switch connected. Its more like there may be some strange connection directly on the board, when I measured voltage on PWR_ON pins, there is just arround 0,4 V and its oscillating like hell. Maybe Super IO?
