Resistors
    Resistors
    How do you determine the wattage on a particular resistor? I have a psu that has a bad 1 megaohm resistor. I don't know the wattage? Can anyone possibly help out? I would appreciate it greatly!!!!
    Re: Resistors
    You can usually tell by the size of the resistor.
    Measure it's length & diameter, then check on the Digikey website for a similar sized resistor to find the wattage.
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
      Re: Resistors
      you tell from the size usually - post a pic.
        Re: Resistors
        Thanks for the quick replies. I called local elec store & was told basically the same thing. (Not RS). The store has them in stock so i am headed that way.
        4 acre electronics... Thanks again for your help. This site is amazing and the people are very knowledgeable and helpful. Thanks again...
