Onkyo TX-NR616 won't stay powered on
    Re: Onkyo TX-NR616 won't stay powered on
    But that is a BGA no and I can't see the pins.
      Unit has been returned to me. Has not been tested with speakers but the speaker icons light up where they didn't before.
      Looking through the vent I can see the hdmi board has been replaced, not repaired.
        Good news.
        Switch over the fan plug, to the empty one, to run constantly.
          Where is this other plug, on the same board ?
            Yes.
            You may have to force it slightly, but it will work. I have it this way on the 616 and 626.
              Hi,working on a TX-NR616..and we are looking for id of Q5416 (K149),,also,if we can get copy of the service manual..Thanks...Blessings !!!
                try reading posts 4 and 5
                  Mistake
                    Hello There,
                    I'm new here but I am searching for the service manual for the Onkyo TX-NR616 can anyone help me with that?
                    Thanks for your help!!
                      Originally posted by Rupke View Post
                      Hello There,
                      Did you try the one in post 4 - anything like?
                        The 609 schematic, is available at elektrotanya.
                          please find attached Onkyo TX NR 616 (also TX NR 414 515 HT-RC470 DTR-30.4 )service manual.
                          Does anybody has REPAIR GUIDE?
                          I have 616 which oacatinally won't stay powered on or does not switch on at all.
                          Also theres no sound , but FM tuner and dislay works,
                          I just repaired burnt AMP part, so going further
                            HI, I got onkyo tx sr616 , it also have same issue no sound. i checked the firmware version its showings D??????????? and A????????????. is it dsp chip failure or its power supply? USB also not recognizing, i have doubt if its dsp failure sound should come pure direct mode right? i am not getting any sound in pure direct mode also
                              I'm trying to repair a 609, with no sound issue as well.
                              I have replaced the DSP, with a D version one and I still have at DSP Netthe ???????
                              It seems like communication, (or most likely lack of it) between ICs could also be the problem.
                              I have got a new nand flash, found a bin file firmware and flashed it, but there is still no change.
                              I don't have audio, USB and network. USB and network are grayed out.
                              At avsforum:
                              http://www.avsforum.com/forum/showth...4#post54833294
                              TJMotter seems like he knows what is talking about.
                                What are the power rails i need to check for DSP, Also i found DSP debug mode in Service manual, it will help me to isolate the no sound problem?
                                  I have never tested the rails.
                                  I have just assumed, that it needs reheating the DSP with an airgun(bad solder job), or it is bad the DSP itself and needs the newer version. Which is, the D version. If you have version C or B, they can be the problem as well. They were recalled, by Texas Instruments.
                                    How i can check the version ?
                                      The new one, should look like this: 830K013DZKB4
                                      Do you see the D in it? Yours, is probably B or C version.
                                        See here #32:
                                        https://www.badcaps.net/forum/showth...t=58095&page=2
                                          Here in US, Onkyo will repair this issue for free.
                                          Maybe, you should check with Onkyo, in India.
                                          Mine it was repaired once, so it is not entitled for another free repair.
                                          I'm also suspecting, firmware issue. Maybe, the firmware upgrade was stopped suddenly, without finishing the process, or installed wrong firmware.
