Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with the tester.
for further testing, i've removed all the wires, yet even placing the tester near the chassis registers as hot, as does the speaker and hdmi terminals. i've tested the receiver using different outlets - same response.
When I set my multimeter to A/C, and with the unit on standby, I place one probe in the grounded outlet of a three prong outlet. Then I touch the other probe to the HDMI port or speaker port. it registers approximately 55 volts. The chassis on the top registers about 3.5 volts, but closer to the outlets goes up to about 30 volts.
the user manual for this receiver does indicate that the speaker terminals do contain hazardous amounts of voltage, but this seems hi to me.
any ideas as to what is happening here? again, this receiver has been working just fine but i'm concerned that it could impact other components (or that it's on its way out).
Thank you for your time.
