pls help help hp dv6-3357sf no light no power .
    the problem cause is a laptop charger
    the charger id pin gives 18.5 v
    when the client plugs in the charger in the laptop the laptop dead .
    hp dv6-3357sf quanta LX6
    no power , no light .
    PU5
    1=18.5v
    9=3.2v
    CN15
    brown wire =2.2v
    red wires=18.5v
    other wires =0v
    Re: pls help help hp dv6-3357sf no light no power .
    is there any why to make a laptop run without charger circuit .
      No but from the Battery it might work
      Test continuity with the help of a multimeter PQ42 Drain to Source & Gate Short
        resistor PR226 burns each time i plug in the charger .
          PQ42 work fine i replace it before but the same problem .
            Ok Remove PR226 and test the resistance both sides of the line
            Test this point’s after to Resistance with Multimètre
            +VAD
              Normally this motherboard requires (page 42 CN15) the AD_ID signal so you only use original or compatible adapters for this model. We should check if there is a short circuit + VA or + VAD or + VIN, check the ohms on those points with the multimeter.
              Report the results
                +VAD
                i test the resistance both sides but no short circuit ; side gives 18.5v and other sides gives me a high ohms value because it's connected with capacitos .
                i can't find pr139 for test VAD_1
                but the pin 14 gives me 2.15v
                and here
                  the motherboard and schematic are different
                  this is PU8
                  and this in blue circle suppose to be PU8
                  but a lot of components are missing like PD17 and pr124 pr141 ...
                    High (no) Res Image LX6:
                    Edit: Look like someone whom was degrade the image resolution, original link at rusfolder was dead.
                    Note: if you got issue when extract it, try use 7zip.
                      this is PU8
                      Seem All matched
                      Hope this helps
                        this is PU8
                        yes this Schematic is Different mesure Voltage in this area , did you resistor PR226 ?
                          • VH28 is output voltage from PU8 as voltage pump to activate PQ42 (need gate higher than source or drain).
                          • if PR226 blown then there is something in circuits, maybe PU8 (maybe other IC too) was broken.
                          • Need to check many net those point as per post7#
                          • Also make sure the charger known as good original adapter ( i think client charger has modify).
                          Note:
                          • I didn't see schematic different with real board....so confuse??
                          • * mark on schematic mean not installed.
                          • but if * then /S mean is short or pad jumper like PR131.
                          Boardview attached and datasheet
                            Note:
                            thank you very much for your help
                            pu8 activate pq42 gate
                            PU8 Vout VH28=0v
                            because no vin
                            pr226 attached directly to pu8 i think the problem in pu8 .
                            is there any way to make the motherboard powered from the power ic directly without charge circuit .
                              Note:
                              pr226 pass the vin to pu8 but pr226 burns
                              i make a jumber from pr226 point to pu8 vin pin but pu8 began to heat so much .
                                PU8 Vout VH28=0v
                                because no vin
                                I assume you have original adapter.
                                +PRWSRC and +VIN weren't short to ground.
                                • There is "good word" on this forum which tell us that The important is you know "How its work". Then you know why its failed.
                                AFAIK Rules mosfet on block charger:
                                • ACFET N-channel MOS required High on gate.(usually from pump ic charger or need external pump from other ICs-depend on circuit schematic).
                                • ACFET P-channel MOS required LOW ( usually have voltage from source/drain-depend on circuit schematic)
                                Required to laptop can turn on:
                                • +PRWSRC and +VIN have ~19V. as supply for LDO and other circuit regulator e.g 3V/5V and LED panel.
                                • PQ42 active/ON, gate required High than drain.
                                • VH28 approx ~25V-28V present via PR15 (check both side of PR15, present or not).
                                PU8
                                • PU8 should work and there aren't pinout have shorted (except pin21)
                                • input present and have output VH28.
                                • P2805PG present (3.3V), VSENSE( approx 2.2V) REG (12V)
                                PU5
                                • PU5 have input (pin1 VAC generated from +VA via PD8>PD6>PR67).
                                • Voltage on both VDDA/VDDP approx 5V
                                • ACAV present 3.3V and generate as ACIN signal via PR84.
                                • Also ACIN signal require for generate PQ19 (PNP-NPN on SC-74 package) so when pin 5 be ON, pin 2 be OFF, then +VAD cross to pin 6 PQ19.
                                • When +VAD present, PQ4 be ON via resistor divider PR192-PR228, Though VH28 present if this fet ON make PQ42 be OFF.
                                • ACIN signal require to make PQ3 be ON and PQ4 be OFF, then PQ42 be ON and generate +PRWSRC/+VIN
                                Pull out the PU8 and check all pin out of pad PU8 for shorted, if shorted gone replace PU8.
                                Note:
                                • Need check carefull, also double check for shorted.
                                • Don't apply power till short gone.
                                Hope you understand with my poor grammar
                                  PU8
                                  PU5
                                  Note:
                                  first i found pin17 vh28 shorted with ground i take off the pc151 but the short still exist
                                  i pull out the pu8 and the short gone .
                                    where i can find P2806 ic .
                                    is there any replacement .
                                      First find in your local store, or try ebay / aliexpress
                                        finally after 6 days of pain i repair the laptop by change the ic p2806
                                        and the laptop work fine
                                        thanks for everyone helps me specially the member on/off
                                        thank you very much .
