TCL - L50E3020FS not turning on
    Re: TCL - L50E3020FS not turning on
    here are some voltages off that inverter.
    VBL 23.97v
    VBL 23.97v
    VBL 23.97v
    VBL 23.97v
    VBL 23.97v
    ERR 5.447v
    BLON 3.26v
    E_PMM 0.894V
    Measured this at the capacitors going into the positive side of the LED connectors.
    C96 23.74v
    C95 23.73v
      VBL 23.97v
      VBL 23.97v
      VBL 23.97v
      VBL 23.97v
      VBL 23.97v
      ERR 5.447v
      BLON 3.26v
      E_PMM 0.894V
      C96 23.74v
      C95 23.73v
      No boosted Voltage at the moment.
      Keep the meter probes on the Plus and minus legs of C95, then turn on the TV to see how high the Voltage jumps up to before settling down to 23.74V.
      There two fuses (F1, F2) on that LED power supply, are they OK?
      The ERROR Voltage may be the clue to the problem in the backlights circuit or the LED, but I do not know if 5V is normal or <1 V is normal for the Error signal.
        C95 voltage spikes to 44.0v then settles to 30.v then goes to 23.74v
        Them fuses are also fine
          So it looks like boost converter goes into shutdown mode. This panel has 8 LED strings so it can be that one or more is bad, You will have to check the Voltage at each one of the VLED- pin each time when you turn on the TV to see what you get on each pin, so leave the meter black probe on the chassis and red probe on VLED- one at time them turn on the TV while watching the meter to see what the Voltage jumps up to and goes down to after 5 seconds on each one of the eight VLED- pins.
            Sorry what kinda results am I looking for 0.800v spiking to 13v?
              Looking for the result of each LED string readings.
