Pentium 4 vent
    Pentium 4 vent
    I have just received a used P4 and the vent hole in the top of the case is open allowing atmosphere into the case. I normally see this hole sealed. It occurs to me that if the hole is open then excess pressure based on high temperature has occurred and popped the vent.
    I have Googled many different ways to get some enlightenment on this vent but have found nothing of use.
    Comment or input please.
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
    Re: Pentium 4 vent
    It's merely a hole for letting out gases during curing the sealers during manufacturing.
    Sounds like you never seen one with a open hole. Especially brand new CPUs.
    Don't worry.
    Cheers, Wizard
      Re: Pentium 4 vent
      Thanks. You right I have not seen this hole open before. All others are sealed. I would expect to be sealed whilst not installed to keep out ambient moisture.
      So no suspicion of a cause.
      Nvidia 8500GT 256Mb
      33 way card reader
      Windows XP Pro SP3
        Re: Pentium 4 vent
        http://en.wikipedia.org/wiki/File:Pe..._northwood.png
        This is fresh P4 CPU.
        Cheers, Wizard
          Re: Pentium 4 vent
          since the mobile varients dont even have the heat spreader and have the bare die exposed its nothing to worry about.
            Re: Pentium 4 vent
            I think the seal would be from the thermal paste that has covered the hole. Usually, I'd sit there and clean the hole out with a blunt stick of some sort or even using sticky tape to clean it out.
            Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
              Re: Pentium 4 vent
              Thanks for all contributions. I have learned something AND the CPU passes all diagnostics.
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
                Re: Pentium 4 vent
                Indeed... without the hole, the airspace between the heatspreader and the CPU die would be air-tight. When the processor heated up, I would imagine it would break that seal one way or another, and it might not be the way you want it to
                Ludicrous gibs!
                  Re: Pentium 4 vent
                  True if not mounted. But I would suspect that if mounted with heatsink compound the vent would be sealed.
                  Nvidia 8500GT 256Mb
                  33 way card reader
                  Windows XP Pro SP3
                    Re: Pentium 4 vent
                    Exactly, the copper heatspeader isn't totally sealed all around on later CPUs as part of improvement manufacturing process and cut down on cost of punching out tiny hole and less use on glue.
                    http://home.arcor.de/xxmartin/A64/a64_ihs.jpg this is also found on Core 2 Duo (using lipped heatspeader).
                    http://www.techpowerup.com/articles/...cking/intel/37 (fails to view with FF, IE viewable. :P)
                    Cheers, Wizard
                      Re: Pentium 4 vent
                      I just looked at it in firefox.
                        Re: Pentium 4 vent
                        Thanks Wizard
                        Those links are a great contribution. Makes facts crystal clear.
                        Nvidia 8500GT 256Mb
                        33 way card reader
                        Windows XP Pro SP3
