Hello, DV6700 , dead but when i plug the adopter the light come on only, i checked mosfet pq30 pin 5.6.7.8 19v pin 1.2.3. 0v pin 4 0v, but mosfet is ok
Dv6700 dead, only adopter light in on
Re: Dv6700 dead, only adopter light in on
u r senior member. u must know that u must start with measure charger ic pins
but is it worth it? that nvidia NB was same shit like nvidia GPUsLast edited by ktmmotocross; 02-12-2019, 01:43 PM.
Originally posted by ktmmotocross View Postu r senior member. u must know that u must start with measure charger ic pins
Originally posted by techtiger View PostPU8 is the Operational Amplifier remove PQ27 with out power test shot to GND all legs if still short you're have 5 resistance & 3 caps to test in this circuit may be one of the caps bad
Originally posted by hispeck View Postpr133 value is 100k, with my DM i get 99.89k
VH28 = 28V only 17V at this pointLast edited by Techtiger; 02-13-2019, 02:23 PM.
I think it's this section that's acting as a charge pump.
Not exactly sure how it works but I think the opamp circuitry around PU8 is an astable multivibrator and PQ27 is some sort of "buffer" to charge/discharge the capacitor PC88 and not affect the characteristics of the astable multivibrator.
This just creates an oscillator for the charge pump (centered around PD12, the dual diode on top right, I cut the markings in the screenshot…) to workOpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostI think it's this section that's acting as a charge pump.
HISPECK the curcit you must get rid of the shortLast edited by Techtiger; 02-14-2019, 11:20 PM.
